Float switch and pump
sfortin
Post by sfortin »
Can Iget help with a code? I have a float switch right now in my aqua on the first floor and my sump is in the basement. when water rise in my aqua because a snail went in my pipe going down. the float switch stop my pump until i'm back and start it again manualy. Right it is the black box you see in the pic doing the job but every time i feed i have to go hit the reset button to re-start the pump
Box with relays to stop pump with reset button
, so i cant use the feed mode!! Now how can i do that with RA?
Set up
Set up
90g
Re: Float switch and pump
Try this:
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Override(Port8,0);
This assumes you are using the LowATO port for your float switch and Port8 for your return pump.
If the float switch is triggered, it will override Port8 to Off and you can clear the override with the Portal or smartphone app after you inspect and know what is wrong.
sfortin
Post by sfortin »
And we insert the code between wich line?
90g
in the custom section of loop()
sfortin
Post by sfortin »
Thanks so so much
90g
sfortin
Post by sfortin »
doesnt seem to work.
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port5,21,0,7,0 );
ReefAngel.StandardHeater( Port7,755,765 );
ReefAngel.Portal( "sfortin" );
90g
sfortin
Post by sfortin »
oupsss it is working but the pump try to start back when i push the activate on my phone but for about half of a second and stop. it's just like trigering. :?
90g
sfortin
Post by sfortin »
Jump to fast on conclusion. It is working super fine my float was defect....
Super service Roberto i'm going to talk of you on my french Québec forum because a lot of my friends are scare to buy because of service (open source) and because of language difference....
90g
Awesome!! :)
sfortin
Post by sfortin »
Now i have another problem..everything was working super fine and now my pump keep stoping for no reason. Sometime it works for one minute and stop. i start it back and work for 10 minutes or 20 or 5 alway different. Took it from port 8 to port 7 and work for about 24 hours and now doing the same thing it was on port 7?????
90g
When the pump stops, does that port show red in the screen display?
sfortin
Post by sfortin »
No it is black
90g
Black?
It is supposed to be green or red.
I'm talking about the port 7 that you have your pump connected to.
sfortin
Post by sfortin »
Yes green
90g
Was it showing green when the pump was off?
sfortin
Post by sfortin »
Yes it was
90g
Try placing a lamp in there.
Does it do the same thing?
Could it be the pump itself?
sfortin
Post by sfortin »
I'll try but if i unplug the pump i hear the relay flikering
90g
Did you check for any water damage in the head unit, svga cable or relay box?
sfortin
Post by sfortin »
No water went there at all it is on my basement wall
90g
sfortin
Post by sfortin »
Just ordered a new module with disp.....
90g
