Can I have a port turn on & then back on & off again later?
Posted: Sat Oct 18, 2014 4:49 pm
I have mh as my main lights and want to have my supplemental T5's run before the MH for a while and then come back on again an hour after the mh turn off; how would I do that?
Would this code work? I simply listed Port2 twice, does that work?
Full code if needed too:
ReefAngel.StandardHeater( Port1,795,800 ); ////2 Heaters
ReefAngel.StandardLights( Port2,14,0,17,0 ); ////T5 Lights 2pm to 5pm
ReefAngel.StandardLights( Port2,23,0,24,0 ); ////T5 Lights 11pm to 12am
ReefAngel.StandardLights( Port3,24,0,15,0 ); ////scrubber lights 12am-3pm 15hrs on 9off
ReefAngel.StandardLights( Port5,17,0,23,0 ); ////Metal Halide 5pm to 11pm
ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs 15ml day
ReefAngel.DosingPumpRepeat( Port7,0,360,26 ); /////alk 360min = 6hrs 78ml day
ReefAngel.DosingPumpRepeat( Port8,0,300,21 ); ////cal 300min = 5hrs 78.75ml day 3cups per gal
ReefAngel.DCPump.SetMode( LongPulse,60,10 );
if (hour()<8)
{Full code if needed too:
InternalMemory.OverheatTemp_write( 845 );
if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,70,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
ReefAngel.AddWifi();
if (ReefAngel.Relay.Status(Port5))
ReefAngel.StandardFan(Port4,813,820);
ReefAngel.Relay.Off(Port4);
ReefAngel.Portal( "davidinga" );
int x,y;
// Parameters
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
// Main Relay Box
// Date and Time
