Need Help with WIFI
Posted: Sun Oct 26, 2014 1:43 am
by mng777777
I cannot figure out the Wifi configuration. I am getting this with the utility:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM5
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM5
< CMD
> ls
< ls
< FL#    SIZ   FLAGS
<   2  86328   3 wifly-GSX-400
<   4  74920   3 web_app-GSX-106
<   7  46632   3 wps_app-GSX-131
<   9  66240   3 eap_app-GSX-101
<  11  37282   0 web_config.html
<  21    512   0 link.html
<  24   1052  10 config
<  25  88548   3 wifly-GSX-441-r1057
<  26   1052  10 user
<  27  88548   3 wifly-GSX-441-r1057
< 122 Free, Boot=25, Backup=27
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s 51brewster
< set w s 51brewster
< AOK
< <4.41>
> set w p 12345678
< set w p 12345678
< AOK
< <4.41>
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=51brewster
< Chan=6
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router TC8305C
Port 2000 is now being forwarded to 0.0.0.0
I followed the Tera Term instructions, but it just sits with a blank screen after I connect the module on both baud rates. I am not sure what to try next???
Please help!
Re: Need Help with WIFI
Posted: Sun Oct 26, 2014 8:39 am
You don't need to.
I'm pretty sure your wifi is already setup.
If it is only blinking green, it is already connected and running.
Posted: Sun Oct 26, 2014 8:42 am
by mng777777
Okay... I figured out how to navigate Tera Term and I read the module's configuration. It is as Follows:
<4.41> get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-55
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.10:2000
NM=255.255.255.0
GW=10.0.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=75.75.75.75
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=51brewster
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=12345678
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
get e
SSID=WiFly-GSX-55
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.10:2000
NM=255.255.255.0
GW=10.0.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=75.75.75.75
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=51brewster
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=12345678
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Does anything stand out as being incorrect and if so, how do I go about correcting it?
Posted: Sun Oct 26, 2014 8:47 am
by mng777777
You are correct! It is working now, I just needed the correct IP address which wasn't shown in the utility but I found as I was reading through the config I just posted
