Heater will not turn on
Posted: Sun Nov 09, 2014 5:38 pm
by midwestornamental
Hello,
Just realized that my heater has not turned on and my tank temp dropped to 73. The heater had been working fine but now when it should be on its not. I can turn it on and off with the phone app but when I select auto nothing happens.
Is there something in my code that would cause this? Here's my code. Any help with this would be greatly appreciated.
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port8,13,30,22,30 );
ReefAngel.Relay.DelayedOn( Port2,3 );
ReefAngel.StandardHeater( Port3,79,80 );
ReefAngel.StandardATO( Port6,3600 );
ReefAngel.StandardLights( Port7,22,30,10,30 );
ReefAngel.Portal( "midwestornamental" , "****" );
Re: Heater will not turn on
Posted: Sun Nov 09, 2014 10:46 pm
by davaraj
I think you should replace this:
With this:
ReefAngel.StandardHeater( Port3,790,800);
Posted: Mon Nov 10, 2014 6:24 am
by cosmith71
davaraj wrote:I think you should replace this:
With this:
Yep, this. 79 degrees is 790, 79.2 degrees is 792. 7.9 degrees is 79. :shock:
Posted: Mon Nov 10, 2014 4:05 pm
Posted: Tue Nov 11, 2014 8:18 am
I've made that mistake myself.. :)
Posted: Fri Nov 14, 2014 10:57 am
lnevo wrote:I've made that mistake myself.. :)
i think we all have at some point. :-)
