ATO Timeout question
Posted: Mon Nov 17, 2014 7:40 am
by westonhull
Hello,
I am using the ATO switch as flood protection for external equipment. In theory, When there is a leak it will fill up tank that is holding equipment. When the level switch is made (float on bottom/wire on top) it shuts off the outlet. However, the way this code is wrote after 60 seconds it times out and it shuts off the outlet when there is no leak. Can I get rid of the timeout
Wes
byte buzzer=0;
byte highfloatflag=0;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.CO2Control( Port1,638,678 );
ReefAngel.SingleATO( true,Port2,60,0 );
highfloatflag = ReefAngel.HighATO.IsActive();
buzzer = highfloatflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetDaylight( buzzer );
ReefAngel.Portal( "westonhull" );
Re: ATO Timeout question
Posted: Mon Nov 17, 2014 9:00 am
Doesn't sound like you wan tto use the SingleATO command. That will turn on the port when the switch is not active and shut it off when the timeout runs out or if the float switch floats up to connect the circuit.
You could just do:
ReefAngel.Relay.Set(Port2, !highfloatflag);
With that if the switch is normal, the port should be on, if the switch is active, the port will be off. If it doesn't work as expected, take out the !
Posted: Mon Nov 17, 2014 10:01 am
by westonhull
Hello,
And thanks for the reply. I just wanted to verify..
So you are saying remove the
And insert;
And if it doens't work as I would expect remove the ! point before the highfloatflag?
Wes
Posted: Mon Nov 17, 2014 11:34 am
Well also make sure it comes after you set highatoflag but yes.
Posted: Mon Nov 17, 2014 4:37 pm
by westonhull
Hello,
Thanks for the reply!
Ok, so I tried with the (!) but it didn't work. So I removed the (!) and it works for the switch but the buzzer keeps buzzing.
ReefAngel.Relay.Set(Port2, highfloatflag);
I tried to change the > to a < thinking it was like PLC's 1 and 0's but I guess that wasn't the case.
Question for you?? When the you get the red or green light for ATO does green mean you have a high ATO or does it mean you don't have a high ATO? When you lift the float switch it goes green.
So what does the (!) do and why did you have it in there? Trying to learn this type of code. Thanks again!
byte buzzer=0;
Posted: Mon Nov 17, 2014 6:05 pm
Change >= to == 1. If it still doesnt do what you expect change it to !=
The ! Means NOT. The reason its always buzzing is because your test is greater than or equal to 1 or less than or equal to 1.
Since the atohighflag will be 0 or 1 we can just use an == or != test. Once we know the state you COULD change it to use < or > but i dont think you should use >= or <=. Does that make sense?
Posted: Tue Nov 18, 2014 11:06 am
by westonhull
Hello,
Ok well that kinda worked...
Original code
100% volume on high but 1% on Low
0% on High but 1% on Low
100% on High but 1% on Low
0 on High but 1% on Low
100% on High but 0% on Low
any other idea's to obtain 100% on High and 0% on Low?
Wes
Posted: Tue Nov 18, 2014 1:59 pm
Ok I see where the probelm may be stemming from...
Let's do this:
if ( highfloatflag > 0 ) buzzer=100; else buzzer=0;
Posted: Tue Nov 18, 2014 5:11 pm
by westonhull
Hello,
Ok, So I tried this;
What happened was it was 0% on High and 100% on Low
I tried
if ( highfloatflag < 0 ) buzzer=100; else buzzer=0;
And it was 0% both ways
I for sure thought your idea would have worked. It sounded like it made sense.
Thanks for the help!
Wes
Posted: Tue Nov 18, 2014 6:46 pm
Ok reason < 0 didn't work is because you aren't getting a negative number so it can't be less than 0... the above should take care of it. Plus I have an error in the code i gave you because highfloatflag is being set AFTER we set the port..
So let's simplify this...
if (highfloatflag) buzzer=100; else buzzer=0;
Basically we're using highfloatflag as a boolean and you can change it's declaration from byte to boolean if you like. So the new code says if highfloatflag is true which means the float switch is active we shut off the port and turn on the buzzer and if it's false it will keep the port on and buzzer will be 0. I'm pretty sure this will do the trick at this point.
Posted: Wed Nov 19, 2014 8:54 am
by westonhull
Hello,
First I want to thank you for sticking through this with me. Well I swapped around the lines and changed the highfloatflag. So the outlet is correct when it goes high it does shut off but the buzzer goes to 100% when the switch is low and goes to 0% on High.
Not to sure what's the deal.
Thanks again!
Wes
Posted: Wed Nov 19, 2014 9:21 am
I told you what to do if that happens. Change == to !=
Can you please post the current code. And confirm that you tried both scenario?
Posted: Wed Nov 19, 2014 9:40 am
by westonhull
Sorry thought I did...
Here is the current code.
byte buzzer=0;
if (highfloatflag) buzzer = 100; else buzzer=0;
I tried the != 1 and that was 100% on high and 1% on low.
I thought I tried the == but I guess, I didn't write that one down on my pad. I'll let you know in a sec.
Posted: Wed Nov 19, 2014 10:50 am
There can be no 1% with the code we have:
Because no matter what it's getting set to 100 or 0.
From the conversations we had, the 1% was when we were doing < and > comparisons...
Posted: Wed Nov 19, 2014 10:54 am
Looking at your code if the outlet is working properly we will want to do this:
if (highfloatflag) buzzer=0; else buzzer=100;
We took away the == and != comparison...so that wasn't relevant. Sorry my bad.
Posted: Wed Nov 19, 2014 11:50 am
by westonhull
Hello,
Well that worked! You are way better at this than I am. Where did you learn this language from? Do you have any books for dummy's for this stuff, if so I need them to get them? Anyways, Here is the final code. Thanks for helping me!
byte buzzer=0;
if (highfloatflag) buzzer = 0; else buzzer=100;
Posted: Wed Nov 19, 2014 12:39 pm
The language is C. You can find many books and sites on the language. It's pretty straight forward. The challenge here I think was just the different approach that was taken with the comparison and a bit of brain fart on my end.
