Some assistance with kalk stirrer
Posted: Wed Nov 19, 2014 1:08 pm
Hello all I have a quick question I would like to ask. I'm implementing my kalk stirrer back online to reduce the amount of 2 part I'm going thru on my sps tank and wanted to run something by the experts as I'm literally only coding using the wizard.
I am going to be running my kalk stirrer separate of my Ato with an aqua lifter and am planning on just using the third dosing pump option on the wizard so I can control it with the Android app also to fine tune it. My question is how would I go about adding in a safe guard to it like if pH reaches 8.5 to tell it not to run that hour. I'm basically trying to break up a gallon of top off into 24 doses (hourly) to run daily with the exception of pH being above 8.5..ive found some similar pH limiting codes but if I'm using the wizard where would I add it? I would just reference the relay I'm using and use the code in custom code here?
Thanks in advance I'm sure this is super easy and I'm just not comprehending it, since I haven't had to mess with the programming in so long I'm just as lost as I was initially.. I have a ton more questions but I need to look for it on the forum before asking here hoping I won't have to bother others if I can find it myself..
Thanks Daniel
Thanks Daniel
