Custom Menu with Flexible Ph Calibration
Posted: Fri Nov 28, 2014 6:19 am
by rrodriguess
Hi
Since my PH is acid, I use the UseFlexiblePhCalibration() option. It used to work ok.
But with my custom menu, I call the SetupCalibratePH() as below:
void MenuEntry5()
ReefAngel.SetupCalibratePH();
It always shows the "simple" Setup Calibrate PH Screen, not the Flexible one (even if the "UseFlexiblePhCalibration" option is set on the "setup" section).
I found in somewhere a SetupCalibrateChoicePH() to use instead of SetupCalibratePH(), but it's not working too (I get a compile error).
Does anyone have any idea?
Best regards
Rafa
Re: Custom Menu with Flexible Ph Calibration
Posted: Fri Nov 28, 2014 6:57 pm
Can I see the code?
Posted: Sun Nov 30, 2014 12:48 pm
by rrodriguess
Sure...
void startTimeRunningRetPump();
void checkMaxSewer();
void checkMinWaterSump();
void checkMaxWaterSump();
void emergencyShutDown();
void WChange();
void DrawCustomMain();
void feedingMode();
// Custom Menu Code
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu1_label[] PROGMEM = "Auto Feed";
prog_char menu3_label[] PROGMEM = "Water Level Calib.";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Emergency Shut Down";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
  menu0_label, menu1_label, menu2_label,
  menu3_label, menu4_label, menu5_label,
  menu6_label, menu7_label//, menu7_label, menu8_label
//auto feed option on feed mode
boolean auto_Feed=false;
//Water Change Status
int wc_status=1;
// 0 - Troca de agua nao esta pronta
// 1 - Pronto para troca de agua
// 2 - transferir do reservatorio para o sump
// 3 - transferir do sump para o esgoto
// 4 - prepara timer dosador
// 5 - inicia dosador
// 6 - preencher reservatorio
boolean RETPUMP_ON_TIME=false;
//Rename ports
#define LIGHTS            Port1
#define RETPUMP           Port2
#define COOLER            Port3
#define CO2UV             Port4
#define WIN               Port5
#define WCHANGE           Port6
#define WOUT              Port7
#define DOSER             Port8
//Labes name - RA MENU
#define RA_NAME_LABEL        "RAFALU"
#define TEMP_LABEL           "TEMP:"
#define PH_LABEL             "PH:"
#define LIGHTS_LABEL         "Lights"
#define RET_PUMP             "RetPump"
#define COOLER_LABEL         "Cooler"
#define CO2UV_LABEL          "CO2/UV"
#define WATER_IN_LABEL       "WIn"
#define WATER_CHANGE_LABEL   "WChange"
#define WATER_OUT_LABEL      "WOut"
#define DOSER_LABEL          "Doser"
//Define WaterLevel Channels
#define WL_SEWER          1
#define WL_REFUGIUM       2
#define WL_SUMP           4
#define WL_RESERVOIR      3
//Define Max and Min PH
#define MAX_PH            610
#define MIN_PH            630
//Define times to Auto Water Change (AWC)
#define WCHANGE_H_T1      9
#define WCHANGE_M_T1      0
#define WCHANGE_H_T2      21
#define WCHANGE_M_T2      0
//Min e Max parameters to Auto Water Change (AWC)
#define MIN_SEWER                10 //maximo tamanho do esgoto para iniciar a troca
#define MIN_RESERVOIR            95 //minimo do reservatorio para iniciar troca parcial
#define MAX_RESERVOIR            100 //maximo para encher reservatorio
#define MAX_SUMP                 60 //valor ideal do sump no final da troca
#define MIN_RESERVOIR_AT_CHANGE  10 //minimo do reservatorio na troca
#define MAX_SEWER                70 //maximo tamanho do esgoto para iniciar a troca
//Minimun Sump Level, preventing pump damage
#define MIN_WATER_SUMP		40
//Doser Time for Auto Water Change (AWC)
#define WCHANGE_DOSER_SECOND     5
//Time On/Off Lights
#define LIGHTS_ON_H      19
#define LIGHTS_ON_M      0
#define LIGHTS_OFF_H     23
#define LIGHTS_OFF_M     59
//Time do auto-feed
#define FEEDING_H_T1     20
#define FEEDING_M_T1     30
#define FEEDING_H_T2     23
#define FEEDING_M_T2     20
//Overheat temp, in celcius
#define OVERHEATTEMP      330
//Max and Min tenperature, in celcius
#define TEMP_MIN		280
#define TEMP_MAX		290
//Seconds return pump is on before checking min-water level.
#define RETURN_PUMP_SECONDS_ON	60
//Number of feeding times done in 15 minutes
#define FEEDING_TIMES			2
//Value to avoid change water on every tyne little variation.
#define PROXY_MAX_SUMP		1.10
  ReefAngel.SetTemperatureUnit(Celsius);  // set to Celsius Temperature
  ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
  //ReefAngel.FeedingModePorts = Port2Bit;
  InternalMemory.OverheatTemp_write(OVERHEATTEMP);
  ReefAngel.Relay.On(RETPUMP);
  // Ports that are always off
  ReefAngel.Relay.Off(WIN);
  ReefAngel.Relay.Off(WCHANGE);
  ReefAngel.Relay.Off(WOUT);
  ReefAngel.Relay.Off(DOSER);
  //Use PH Flexible Calibration
  //Lights Control
  ReefAngel.StandardLights(LIGHTS,LIGHTS_ON_H,LIGHTS_ON_M,LIGHTS_OFF_H,LIGHTS_OFF_M);
  //Fam control
  //ReefAngel.StandardFan(COOLER,TEMP_MIN,TEMP_MAX);
  // CO2/UV Control
  ReefAngel.CO2Control(CO2UV,MIN_PH,MAX_PH);
  //Auto Water Change (AWC) function
  WChange();
  //Configra gatilho de 2 minutos de bomba de retorno em execucao
  //Function to prevent pump burn
  //Funcao para deixar o Sump na medida certa
  //Security function on water max level
  checkMaxSewer();
  //feeding mode
  feedingMode();
void startTimeRunningRetPump(){
  static boolean timerOn=false;
  static long finalTime=0;
  if(ReefAngel.Relay.Status(RETPUMP) && !timerOn) {
    finalTime = now()+RETURN_PUMP_SECONDS_ON;
    timerOn=true;
  if(now()>=finalTime && ReefAngel.Relay.Status(RETPUMP)) {
    RETPUMP_ON_TIME=true;
  if(!ReefAngel.Relay.Status(RETPUMP)){
    timerOn=false;
  if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)>=MAX_SEWER){
  //se agua do sump baixa e bomba retorno ligada
  if(RETPUMP_ON_TIME){
    if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)<=MIN_WATER_SUMP){
void emergencyShutDown(){
  wc_status=0; //inviabiliza futuras trocas de agua
  ReefAngel.Relay.Override(WIN,0);
  ReefAngel.Relay.Override(WCHANGE,0);
  ReefAngel.Relay.Override(WOUT,0);
  ReefAngel.Relay.Override(DOSER,0);
  ReefAngel.Relay.Override(RETPUMP,0);
  ReefAngel.Relay.Override(CO2UV,0);
  //se estiver em troca parcial, não mecher.
  if(wc_status==1){
    if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)> (MAX_SUMP*PROXY_MAX_SUMP)  && RETPUMP_ON_TIME){
      ReefAngel.Relay.On(WOUT);
    else {
void WChange()
  static unsigned long wcDosingTimer;
  //realiza somente se a bomba retorno esta funcionando a mais de alguns minutos
    switch (wc_status){
    case 1:
      //se execucao manual ou mediante algum horario
      if((ReefAngel.DisplayedMenu==WATERCHANGE_MODE) || (hour()==WCHANGE_H_T1  && minute()==WCHANGE_M_T1) || (hour()==WCHANGE_H_T2 && minute()==WCHANGE_M_T2))
        if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MIN_RESERVOIR){
          wc_status=6;
        else{
          if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)<=MIN_SEWER){
            wc_status=2;
      break;
    case 2:
      //transferir do reservatorio para o sump
      if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)>(MIN_RESERVOIR_AT_CHANGE)){
        ReefAngel.Relay.On(WCHANGE);
      else{
        wc_status = 3;
      break;
    case 3:
      //transferir do sump para o esgoto
      if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)>(MAX_SUMP)){
      else{
        wc_status = 4;
      break;
    case 4:
      //prepara timer dosador
      wcDosingTimer= now() + WCHANGE_DOSER_SECOND;
      wc_status = 5;
      break;
    case 5:
      if (now()<wcDosingTimer) {
        ReefAngel.Relay.On(DOSER);
      else {
        wcDosingTimer=0;
        wc_status = 6;
      break;
    case 6:
      //preencher reservatorio, prepara proxima troca
      if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MAX_RESERVOIR){
        ReefAngel.Relay.On(WIN);
      else{
        wc_status = 1;
      break;
  else {
    wc_status=1;
void feedingMode(){
  static byte nrFeedings=0;
  static boolean afeed=false;
  static long timeToRun;
  static long feeding;
  //somente se nao estou fazendo troca automatica
  if(wc_status==1){
    timeToRun = 900/(FEEDING_TIMES+1);
    if(auto_Feed || ((hour()==FEEDING_H_T1  && minute()==FEEDING_M_T1) || (hour()==FEEDING_H_T2 && minute()==FEEDING_M_T2))){
      auto_Feed=false;
      afeed=true;
      feeding = now()+timeToRun;
      if(!(ReefAngel.DisplayedMenu==FEEDING_MODE)) ReefAngel.FeedingModeStart();
    ReefAngel.Relay.Set(RETPUMP, !(ReefAngel.DisplayedMenu==FEEDING_MODE) );
    if(afeed){
      if(now()>=feeding && nrFeedings < FEEDING_TIMES){
        //if(ReefAngel.Relay.Status(LIGHTS)){
        ReefAngel.Relay.Set(COOLER,!ReefAngel.Relay.Status(COOLER));
        nrFeedings++;
      if(nrFeedings == FEEDING_TIMES){
        nrFeedings=0;
        afeed=false;
  //Titulo Inicial
  ReefAngel.LCD.DrawDate(6, 64);
  ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 40, 4 , RA_NAME_LABEL);
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
  //Temperatura tanque principal
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 6, 15, TEMP_LABEL);
  char text[7];
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 44, 15, text);
  //PH
  ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 26, PH_LABEL);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 44, 26, text);
  //WATER LEVEL 01
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 38, "    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SEWER), 1);
  char str[80];
  strcpy (str,"SEWER:");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 38, str);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 38,"    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_REFUGIUM), 1);
  strcpy (str,"REF: ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 38,str);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 50, "    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR), 1);
  strcpy (str,"RES:  ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 50, str);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 50,"    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SUMP), 1);
  strcpy (str,"SUMP:");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 50,str);
  //Portas
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,84,RET_PUMP);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,94,CO2UV_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,104,WATER_CHANGE_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,114,DOSER_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,84,LIGHTS_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,94,COOLER_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,104,WATER_IN_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,114,WATER_OUT_LABEL);
  ReefAngel.LCD.DrawCircleOutletBox(60, 86, TempRelay, true);
void MenuEntry1()
  auto_Feed=false;
void MenuEntry2()
  auto_Feed=true;
void MenuEntry3()
void MenuEntry4()
  ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry5()
  ReefAngel.SetupCalibrateChoicePH();
void MenuEntry6()
  // Clear the screen
  // Display some text on the screen
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 5, 10, "Turn Everything Off");
  // Turn off the ports
  ReefAngel.Relay.Write();
void MenuEntry7()
  ReefAngel.SetupDateTime();
void MenuEntry8()
  ReefAngel.DisplayVersion();
Posted: Sun Nov 30, 2014 12:51 pm
by rrodriguess
Ahhh dont you mind the comments in portuguese... coding in progress...
Rafa
Posted: Sun Nov 30, 2014 1:25 pm
Just so we are on the same page, did you download and update your libraries with the dev branch?
Posted: Sun Nov 30, 2014 2:09 pm
by rrodriguess
Let me make surge of it, and I get back to you. I will use this library:
https://github.com/reefangel/Libraries
Is that it?
Posted: Sun Nov 30, 2014 2:12 pm
Yes, that is the currently released libraries.
You should use that version unless you were testing or using a feature that is currently not release.
Posted: Sun Nov 30, 2014 2:42 pm
by rrodriguess
To be able to use the SetupCalibrateChoicePH() which one should I use?
Posted: Sun Nov 30, 2014 3:06 pm
Use the currently released
Posted: Sun Nov 30, 2014 4:32 pm
by rrodriguess
Roberto
Just double checked.. I am using the currently release. I get the following error:
Watchdog Timer
Version Menu
Custom Main Screen
Extra Font - Medium Size (8x8 pixels)
Date/Time Setup Menu
Custom Menu
Calibrate pH Menu with Choices
Number of Menu Options: 8
In file included from FreshWaterWord_1_17.cpp:30:
/home/mint/Desktop/Arduino/libraries/ReefAngel/ReefAngel.h:233: error: expected unqualified-id before ‘)’ token
FreshWaterWord_1_17.cpp: In function ‘void MenuEntry5()’:
FreshWaterWord_1_17:558: error: expected unqualified-id before ‘(’ token
Posted: Sun Nov 30, 2014 6:49 pm
The bug is on the feature.txt file.
It's located at \Arduino\update\
Replace this:
SetupCalibrateChoicePH,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with Choices
With this:
SETUP_CALIBRATEPH_CHOICE,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with Choices
Posted: Mon Dec 01, 2014 2:45 am
by rrodriguess
Roberto.. tks
It compiled alright. As soon as I get home I will upload and test it.
Rafa
Posted: Wed Dec 03, 2014 4:51 pm
by rrodriguess
Tks Roberto... it worked just fine!
