Reef Angel Android App Dimming error
Posted: Fri Dec 12, 2014 1:26 pm
I've recently installed a dimming module, and I find that I'm getting errors when I try to change the dimming values using the Reef Angel Android App.
Sometimes it works, sometimes it doesn't. I haven't nailed it down for sure, but it may only be when I try to set a channel to less than 10%.
Errors I've gotten are:
Error 13: Device Authentication Error
Error 24: XML Read Exception
Error 13: Connection Reset by Peer
Error 23: At line 1, column 518: unclosed token
Is this perhaps a coding issue not an app issue?
