Lunar Expansion Module
Posted: Tue Dec 16, 2014 4:22 pm
Hi guys,
I have a refugium and frag tank in my sump and would like to control the lighting inside the cabinet. is it possible to use a single Lunar Hub to control 2 moon cycles? i.e.: the hub description says it can control up to 20 moonlight modules - can each of these be controlled on a separate channel?
What i want to achieve is alternating lunar cycles: the standard moon cycle for the DT while also controlling a reverse moon cycle inside the cabinet?
Cheers,
Alex
Cheers,
Alex
