WIFI connection
Posted: Sun Dec 28, 2014 10:50 pm
by estanoche
Trying to install a new wifi module (had a gen 1 unit that I could never upgrade past v2.3 and it was still the devil) and can't seem to get my new 4.41 unit to hold a connection.
It shows connected; but after about a minute the unit goes to fast "no IP" blink mode and I really never have a connection even though it says I do. I've gone through my router settings, but the old unit I had worked, with timeout issues, so I really don't know/think what may need to be different with this firmware.
<4.41> get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-c8
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.10.10:2000
NM=255.255.255.0
GW=192.168.10.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=75.75.75.75
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=reefangel
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=estanoche
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
Help? Suggestions? Currently I have this on a Motorola Surfboard SBG6580; WPA2-PSK and WPA-PSK enabled with TKIP & AES active just to try not to limit myself.
Only thing I see different from my previous code is this one doesn't select WPA2 as a wlan auth and only does mixed..
Also - when I listen on teraterm, it gives me a "disassociated - LOST-AP " message. From what I understand that is just telling me what I already know, that it really isnt associated even though I want it to.
And - I have done this and ran this macro multiple times: http://forum.reefangel.com/viewtopic.php?f=3&t=4601
Re: WIFI connection
Posted: Mon Dec 29, 2014 9:20 am
It looks like it is disconnecting from the router for loss of signal.
How far is it from the router?
Re: WIFI connection
Posted: Mon Dec 29, 2014 3:14 pm
by estanoche
Hmm well; when I put it right next to the router I get a signal - but I cannot get it to respond to a ping. Since I still have my antique unit, I did some live testing - same network.
Antique unit connects, works as programmed:
get e
WiFly Ver 2.38, 12-11-2012 on 131C11
Beacon=102
Probe=5
Reboot=0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
IF=UP
DHCP=ON
IP=192.168.10.12:2000
NM=255.255.255.0
GW=192.168.10.1
PROTO=TCP,HTTP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
DNS=75.75.75.75
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=reefangel
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Sensor=0x0
SensePwr=0x0
Programming on new unit does not connect (although my router indicates it is connected):
get e
SSID=WiFly-GSX-c8
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=0.0.0.0
GW=0.0.0.0
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=reefangel
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
PS - I tried auth 0 to set the new unit to OPEN like the antique, that doesn't help.
Other ideas? What incongruity have I missed?
Re: WIFI connection
Posted: Mon Dec 29, 2014 5:56 pm
Are you able to try on a different router?
Neighbor, work or friends?
If so, does the same problem persist?
Re: WIFI connection
Posted: Wed Jan 07, 2015 12:21 pm
by estanoche
Hmm I can put testing on my old router on my list of things to do - issues I foresee... 1) the router only supports WPA1-PSK, does the 4.0 firmware support WPA1 OK ? 2) To get it to work I have to bridge from my all in 1 router/cable modem which I have never tried before... I could just never set it up right and fail all the tests.
What kind of router do you use that has proven to be error free? This All in 1 unit gives me headaches from time to time - I can imagine I get mad at it enough one day to throw it out the window and start over with something else that I know is stable.
Re: WIFI connection
Posted: Wed Jan 07, 2015 4:35 pm
by estanoche
Ha - and I have no idea what I did today, but it has been connected for 2+ hours and counting ...
Programmed the unit using the WIFI Attachment Setup Utility, which gave me an associated IP of 0.0.0.0 and then I decided what the heck, and hit the "update firmware" button which progressed farther through the process than normal and failed at "getting WPS data".
Plugged it in to my head unit - and yeah, its working.
