Page 1 of 2
New DCPump Modes - How to code???
Posted: Wed Dec 31, 2014 8:06 am
by Paul_Velasco
Is there a place where the new modes are explained and how to code? Getting ready to upgrade to new LIB 1.1.1 and would like to include the new modes.
Thanks in advance and apologies if this has been answered before. I tried searching.
Re: New DCPump Modes - How to code???
Posted: Thu Jan 01, 2015 5:45 am
by cosmith71
They're easy if you're using the DCPump libraries already.
ReefAngel.DCPump.SetMode(Else,midpoint,offset);
Generates a random flow from midpoint-offset to midpoint+offset. For example, if you use:
ReefAngel.DCPump.SetMode(Else,50,20);
You'll get a random flow that ranges between 30 and 70.
ReefAngel.DCPump.SetMode(Gyre,speed,duration,threshold);
Generates a long, slow sine wave. Speed is the max speed, duration (in minutes), and threshold is the minimum speed. If you leave off threshold it will use 30 (or whatever you have set with DCPump.Threshold).
I'm not familiar with Sine. Maybe someone else can chime in.
Posted: Thu Jan 01, 2015 5:46 am
by cosmith71
There are release notes here:
http://forum.reefangel.com/viewtopic.php?f=7&t=1473
Posted: Fri Jan 02, 2015 7:04 am
by Paul_Velasco
Thanks man, you are always a great help!!!!
Anyone with the Sine mode help? Or will I be just duplicating with the Gyre Mode.
Posted: Fri Jan 02, 2015 7:09 am
by cosmith71
You're welcome!
Posted: Tue Jan 13, 2015 4:27 pm
by Paul_Velasco
 ReefAngel.PWM.SetDaylight( GyreMode(30,100,10,true); //Ramp up to 70% in 10mins in sync mode
 ReefAngel.PWM.SetActinic( SineMode(30,100,10,true)); //Ramp up to 70% in 10mins in sync mode
GyreMode is not working?
Posted: Wed Jan 14, 2015 5:19 am
by cosmith71
That code will run it from 30% to 10% over 100 minutes.
Jebao's generally don't work well under 30%. Also, this is a very long cycle time (1 hour 40 minutes). What is it not doing?
Posted: Wed Jan 14, 2015 8:51 am
by Paul_Velasco
The pumps limit is right at 30%, verified operation at that level.
I thought the 10 was the duration, so 10 minutes not 100? Otherwise I will change the code.
It does not recognize GyreMode. The text, GyreMode, stays black in my IDE. Usually if accepted it will turn the text to orange. Load the program and the pump runs at 0% (Looking in my RA Client). I have Lib V 1.1.1 loaded as well. Else mode and Sine mode work perfect.
Posted: Wed Jan 14, 2015 9:06 am
The color change on the text is probably an oversight on my part.
We can pick and choose which words turn which color.
I'll add GyreMode to the list.
Posted: Wed Jan 14, 2015 11:15 am
by Paul_Velasco
So is duration wrong?
This is how I coded
GyreMode( Low %, High%, Duration min, bolean)
Is it really
GyreMode( Low %, Duration min, High%, bolean)
Posted: Wed Jan 14, 2015 11:20 am
by cosmith71
I believe it's high, duration minutes, low.
Posted: Wed Jan 14, 2015 11:31 am
by Paul_Velasco
OK will try
I coded it in error at first, gave me compile error Too few arguments , GyreMode (Byte, Byte, Int, Boolean). So I thought the first two arguments were Low% and High%.
Will change to make the duration in the middle.
Posted: Wed Jan 14, 2015 11:50 am
This is the function arguments:
byte GyreMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
Posted: Wed Jan 14, 2015 12:26 pm
by cosmith71
There you go. :)
Posted: Wed Jan 14, 2015 7:22 pm
by Paul_Velasco
ReefAngel.PWM.SetDaylight (GyreMode(40,100,10,true) ); // Short pulse at 60% with 200m
ReefAngel.PWM.SetActinic(GyreMode(40,100,10,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
(comments are wrong)
It is definitely not working with this code??? Anything amiss?
Posted: Wed Jan 14, 2015 7:25 pm
by cosmith71
Post the rest of the code.
Posted: Thu Jan 15, 2015 6:49 am
by Paul_Velasco
unsigned long LastUpdate1=0;    // For virtual Vinegar dosing pumps
unsigned long LastUpdate2=0;    // For virtual Magnesium dosing pumps
unsigned long LastUpdate3=0;    // For virtual ATO dosing pump
    ReefAngel.FeedingModePortsE[0] = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port7,750,755 );
    ReefAngel.StandardFan( Port8,760,800 );
    ReefAngel.Relay.DelayedOn( Box1_Port1,5 );
    ReefAngel.StandardLights( Box1_Port3,20,0,8,0 );
    //ReefAngel.WaterLevelATO( Box1_Port7,60,48,50 );
    ReefAngel.RF.SetMode( Constant,75,100);
    //Use salinity compensation
    ReefAngel.Salinity.SetCompensation(0);
    //Only use the ATO when no one is in house and there is water in reservior
    //Use Channel 4&2 as Redundant Controls.
    if (hour()>=6 && hour()<=23)
      if (ReefAngel.WaterLevel.GetLevel(4)<=47 && ReefAngel.WaterLevel.GetLevel(1)>0) ReefAngel.Relay.On(Box1_Port7);
      if (ReefAngel.WaterLevel.GetLevel(4)>50) ReefAngel.Relay.Off(Box1_Port7);
//Turn-off Skimmer whhen skimmer tank is full
    if (ReefAngel.WaterLevel.GetLevel(3)>=90)
    }else{
//How about some WaveMotion with the Vortech
    static time_t feeding;
// Time schedule first
    if (hour()>=6 && hour()<7) {
      ReefAngel.PWM.SetDaylight( LongPulseMode(30,100,5,true) ); // Long pulse hi/low 50%20% 10s pulse on sync mode
      ReefAngel.PWM.SetActinic( LongPulseMode(30,100,5,false) ); // Long pulse hi/low 50%20% 10s pulse on anti-sync mode
    } else if (hour()>=7 && hour()<8) {
      ReefAngel.PWM.SetDaylight ( ElseMode( 80,20, true) ); // Short pulse at 60% with 200m
      ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
    } else if (hour()>=8 && hour()<10) {
      ReefAngel.PWM.SetDaylight( SineMode(30,100,180,true)); //Ramp up to 100% in 3mins in sync mode
      ReefAngel.PWM.SetActinic( SineMode(30,100,180,true)); //Ramp up to 100% in 3mins in sync mode
    } else if (hour()>=10 && hour()<11) {
      ReefAngel.PWM.SetDaylight( ShortPulseMode(30,100,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
      ReefAngel.PWM.SetActinic( ShortPulseMode(30,100,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
    } else if ( (hour()>=11 && hour()<13) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
      ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,100,500,true) );
      ReefAngel.PWM.SetActinic( NutrientTransportMode(30,100,500,false) );
    } else if (hour()>=11 && hour()<13) {
      ReefAngel.PWM.SetDaylight( ReefCrestMode(90,10,true) ); // ReefCrest at 70% +/- 20% on sync mode
      ReefAngel.PWM.SetActinic( ReefCrestMode(90,10,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
    } else if (hour()>=13 && hour ()<14) {
      ReefAngel.PWM.SetDaylight( ShortPulseMode(30,100,500,true) ); // Short pulse at 60% with 200ms pulse on sync mode
      ReefAngel.PWM.SetActinic( ShortPulseMode(30,90,500,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
    } else if (hour()>=14 && hour()<15) {
      //ReefAngel.PWM.SetDaylight ( GyreMode( 30, 100, 10, true) ); // Short pulse at 60% with 200m
      //ReefAngel.PWM.SetActinic( GyreMode(30,100, 10, true) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
    } else if (hour()>=15 && hour()<16) {
      ReefAngel.PWM.SetDaylight( SineMode(30,100,30,true)); //Ramp up to 70% in 10mins in sync mode
      ReefAngel.PWM.SetActinic( SineMode(30,100,30,true)); //Ramp up to 70% in 10mins in sync mode
    } else if (hour()>=16 && hour()<17) {
      ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,100,250,true) );
      ReefAngel.PWM.SetActinic( NutrientTransportMode(30,100,250,false) );
      //ReefAngel.PWM.SetDaylight( ElseMode(75,20,true) );
      //ReefAngel.PWM.SetActinic( ElseMode(75,20,false) );
      //ReefAngel.PWM.SetDaylight( ReefCrestMode(75,25,true) ); // ReefCrest at 70% +/- 20% on sync mode
      //ReefAngel.PWM.SetActinic( ReefCrestMode(75,25,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
    } else if (hour()>=17 && hour ()<19) {
      ReefAngel.PWM.SetDaylight( SineMode(30,100,20, true)); //Ramp up to 70% in 10mins in sync mode
      ReefAngel.PWM.SetActinic( SineMode(30,100,20, false)); //Ramp up to 70% in 10mins in sync mode
      //ReefAngel.PWM.SetDaylight( ShortPulseMode(10,100,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
      //ReefAngel.PWM.SetActinic( ShortPulseMode(10,100,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
    } else {
      //ReefAngel.PWM.SetDaylight (GyreMode(40,100,10,true) ); // Short pulse at 60% with 200m
      //ReefAngel.PWM.SetActinic(GyreMode(40,100,10,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
      //ReefAngel.PWM.SetDaylight ( ElseMode(80,20, true) ); // Short pulse at 60% with 200m
      //ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
// If we are feeding override the schedule
      ReefAngel.PWM.SetDaylight(30);
      ReefAngel.PWM.SetActinic(30);
      //Vortech
      ReefAngel.RF.SetMode( Constant,50,100 );
      feeding=now();
// If we have finished feeding, start NTM for 3 hours
    if (now()-feeding < 3*SECS_PER_HOUR)
      //vortech
      ReefAngel.RF.SetMode(Smart_NTM,100,10);
//Do not use the memory bits inside the Vortech
//Time based Vortech Schedule
    if (hour()>=9 && hour()<10) {
      ReefAngel.RF.SetMode(ReefCrest,100,10);
      ReefAngel.RF.SetMode(Smart_TSM,100,10);
    } else if (hour()>=11 && hour()<12) {
      ReefAngel.RF.SetMode(ShortPulse,100,10);
    } else if (hour()>=12 && hour()<13) {
    } else if (hour()>=13 && hour()<14) {
    } else if (hour()>=14 && hour()<15){
      ReefAngel.RF.SetMode(LongPulse,100,10);
    } else if (hour()>=17 && hour()<18) {
    } else if (hour()>=18 && hour()<19) {
    } else if (hour()>=19 && hour()<20) {
    } else if (hour()>=20 && hour()<21){
    } else {
      //ReefAngel.RF.SetMode(Lagoon,40,10);
       ReefAngel.RF.SetMode(Else, 80,20);
//Code to make Vodka Dosing Work one time a day for 11 mins
//Turn on at 8:00 AM
    ReefAngel.DosingPumpRepeat(Box1_Port6,480,1440,450);
///Code to make Vinegar Dosing Work 4 mins
    ReefAngel.DosingPumpRepeat(Box1_Port8,0,60,120);
///Do not turn on Vinegar if lights are off
    if (hour()<=8 || hour()>21) {
//Code to make Magnesium Dosing Work
    ReefAngel.DosingPumpRepeat(Box1_Port4,15,60,120);
//Code to check that the dosing pumps are running
// *******************  Turn on imaginary relays for 5 minutes when dosing pumps activate so Portal can track them  *******************
// Vinegar port
    if (ReefAngel.Relay.Status(Box1_Port8) && LastUpdate1==0)
      LastUpdate1 = now();
      ReefAngel.Relay.On (Box2_Port1);
    if (now() - LastUpdate1 >= 300 && LastUpdate1 != 0)
      LastUpdate1 = 0;
      ReefAngel.Relay.Off (Box2_Port1);
// Magnesium Port
    if (ReefAngel.Relay.Status(Box1_Port4) && LastUpdate2==0)
      LastUpdate2 = now();
      ReefAngel.Relay.On (Box2_Port2);
    if (now() - LastUpdate2 >= 300 && LastUpdate2 != 0)
      LastUpdate2 = 0;
      ReefAngel.Relay.Off (Box2_Port2);
// ATO Port
    if (ReefAngel.Relay.Status(Box1_Port7) && LastUpdate3==0)
      LastUpdate3 = now();
      ReefAngel.Relay.On (Box2_Port3);
    if (now() - LastUpdate3 >= 300 && LastUpdate3 != 0)
      LastUpdate3 = 0;
      ReefAngel.Relay.Off (Box2_Port3);
// This should always be the last line1
    ReefAngel.Portal( "Paul_Velasco" );
Here it is. I am trying to code a more random wave patttern, but that is for another day.
Posted: Thu Jan 15, 2015 7:01 am
by cosmith71
How is it not working? What is it doing/not doing?
Posted: Thu Jan 15, 2015 7:55 am
by Paul_Velasco
(I uncomment in the else statement and comment the other mode so the gyre is only one working)
When I look at the ReefClient on my desktop I get 0% for the pumps on the two channels when running GyreMode.
I physically look at the pumps and they are stopped.
Any of the other modes I run on those channels work perfectly.
Raised the lower limit to 40% thinking that may have been the problem.
Posted: Fri Jan 16, 2015 7:30 am
by Paul_Velasco
Anyone have any ideas why Gyre is not working
Posted: Fri Jan 16, 2015 8:54 am
by cosmith71
I uncommented the GyreModes and uploaded your code to one of my RA+ units. I manually changed the time to 1400 and 1900 and it worked both times.
The only thing I can recommend is doing an un-install/re-install of the the RA software on your computer. Maybe you have a corrupted library.
Posted: Fri Jan 16, 2015 9:03 am
by cosmith71
The only potential problem I see is that between 1400 and 1500 you have both pumps set to sync. That means they will both be on for 10 minutes and off for 10 minutes at the same time.
Posted: Sat Jan 17, 2015 7:48 pm
by Paul_Velasco
Ok I will change sync
Will try to do a clean install
Posted: Mon Jan 19, 2015 7:11 am
by Paul_Velasco
Reinstall did not work?
Is there something in the registry to delete?
Posted: Mon Jan 19, 2015 9:05 am
Upload this code and see what you get:
    ReefAngel.AddStandardMenu();  // Add Standard Menu
It worked for me.
Posted: Tue Jan 20, 2015 6:46 am
by Paul_Velasco
To Close this out:
Uninstalled and resinstalled Arduino application, did this twice. Then reinstalled once again last night and it worked?? No idea why it just worked.
Posted: Tue Feb 03, 2015 9:45 am
by davaraj
cosmith71 wrote:They're easy if you're using the DCPump libraries already.
Are these DCPump codes meant for a single pump? How do I code for 2 pumps connected to the Actinic and DayLight channels?
Dr Davaraj
Posted: Tue Feb 03, 2015 11:37 am
You will have lines like this in the setup section of your code
ReefAngel.DCPump.DaylightChannel = AntiSync;
If you want to disable one channel you can set it to None.
If you want both pumps to do the same thing then set them both to Sync.
Posted: Tue Feb 03, 2015 10:47 pm
by davaraj
lnevo wrote:You will have lines like this in the setup section of your code
I have recoded like this. I do have
In the setup section.
///////Place your custom code below here
if (hour()>=4 && hour()<8)
ReefAngel.DCPump.SetMode(Sine, 30, 40);
else if (hour()>=8 && hour()<12)
ReefAngel.DCPump.SetMode(TidalSwell, 55); // TidalSwell at 55%
else if (hour()>=12 && hour()<16)
ReefAngel.DCPump.SetMode(millis();1200>750?50:0);
else if (hour()>=16 && hour()<19)
ReefAngel.DCPump.SetMode(LongPulse, 0, 50, 10); // Long pulse at 0% to 50% with 10s pulse
else if (hour()>=19 && hour()<23)
ReefAngel.DCPump.SetMode(Else, 40, 10); // ElseMode 40 +/- 10%
ReefAngel.DCPump.SetMode(Gyre, 30, 50, 10); //GyreMode from 30% to 50% for 10 minutes
When I run 'verify' code it compiles, except for:
ReefAngel.DCPump.SetMode(TidalSwell, 55); and
When I insert this:
ReefAngel.DCPump.SetMode(TidalSwell, 55, true); it compiles for this mode. However 'millis' gives errors. How do I code for millis (standing wave like W1 in Jebao controller)?
Posted: Wed Feb 04, 2015 4:14 am
ReefAngel.DCPump.SetMode(TidalSwell 55); and
You need 3 arguments to SetMode separated by a comma. Mode Speed and Duration. The first only has 2 and no comma and the second, that code block represents one argument and it represents a speed.
Try this:
ReefAngel.DCPump.SetMode(TidalSwell,55,0);
ReefAngel.DCPump.SetMode(Constant,millis();1200>750?50:0,0);
