Send mulitple bytes on Wire.receive()
Posted: Tue Dec 20, 2011 10:53 pm
I've been playing with a couple ideas to monitor flow rates and lighting levels. First, I had to figure out how to hook up a second Arduino to the main to see the data output. With your help, I got this to work nicely with a photodiode http://forum.reefangel.com/viewtopic.php?f=19&t=493. I then received a couple of flow meters to try on the same Arduino http://forum.reefangel.com/viewtopic.php?f=4&t=462 to see if I can measure flow. These too look to be working OK on the Arduino and the data can be sent to the main display like the photodiode. However, I haven't had any luck trying hook both up on the same breadboard and display both using the Wire functions. They work on serial display, but I can only get one to work on the main. Any ideas of how to tell the main there are 2 bytes to receive and to display them seperately? I was hoping to use the second board to monitor a few different lighting areas and altleast two water lines, but I have to seperate out the data sent so the display understands each.
-Jon
Here is the current Master pde:
And here is the slave pde:
-Jon
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
#define photodiode 9
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater1";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "MHalide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Main";
prog_char relay8_label[] PROGMEM = "Fan";
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TK:");
if (ReefAngel.Params.Temp1>830) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_RED, 23, 13, 10);
else if (ReefAngel.Params.Temp1>810) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_ORANGE, 23, 13, 10);
else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 23, 13, 10);
// Display the Room temperature
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,5,23,"RM:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, 0, 23, 23, 10);
// Display the Sump temperature
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,5,33,"FL:");
ReefAngel.LCD.DrawSingleMonitor(Wire.receive(), 0, 23, 33, 1);
// Display the PH with color sensors
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 64, 13,"PH:");
if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_RED, 82, 13, 100);
else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_ORANGE, 82, 13, 100);
else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 82, 13, 100);
// Display the % Moonlight
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 23,"LT:");
ReefAngel.LCD.DrawSingleMonitor(Wire.receive(), 0, 82, 23, 1);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 33,"WV:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33,"-->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33,"<--"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33," O "); //port5 and port 6 off, wavemaker delay
ReefAngel.LCD.DrawOutletBox(12, 45, TempRelay);
//#ifdef RelayExp
// draw 1st expansion relay
//TempRelay = ReefAngel.Relay.RelayDataE[0];
//TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
//TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
//ReefAngel.LCD.DrawOutletBox(12, 55, TempRelay);
//#endif // RelayExp
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,33,135,43);
ReefAngel.LCD.DrawText(0, DefaultBGColor,105,33,t);
if (t>300) ReefAngel.Timer[1].ForceTrigger();
ReefAngel.LCD.DrawGraph(1, 75);
ReefAngel.Init(); //Initialize controller and start web banner timer
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.WaterChangePorts = B10110000;
// ReefAngel.OverheatShutoffPorts = B00000111;
// ReefAngel.LightsOnPorts = B00001100;
ReefAngel.Relay.On(Port5);
ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port7);
// Wire.begin();
// Serial.begin(9600); // serial connection
// Specific functions
//1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
ReefAngel.StandardHeater(Port1,788,792);
ReefAngel.StandardHeater(Port2,770,792);
ReefAngel.MHLights(Port3,10,0,20,0,5);
ReefAngel.StandardLights(Port4,9,0,21,0);
ReefAngel.StandardFan(Port8,792,820);
// Wavemaker Code with night option
if (ReefAngel.Timer[1].IsTriggered() )
if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
{ //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
// byte endPWM, byte Duration, byte oldValue)
wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
if (wmdelay)
ReefAngel.Timer[1].SetInterval(wmpulse); // WM delay function from 30-170 sec.
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(200-wmpulse); // WM bursts timing from 170-30 sec.
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-10p normal wave settings
//Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
//other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
pinMode(highATOPin,OUTPUT);
digitalWrite(highATOPin,HIGH);
{pinMode(highATOPin,OUTPUT);
digitalWrite(highATOPin,LOW);
//Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
// Web Banner stuff
ReefAngel.WebBanner();
//receive Light readout
Wire.requestFrom(photodiode,2);
/* Photocell simple testing sketch.
Connect one end of the photocell to 5V, the other end to Analog 0.
Then connect one end of a 10K resistor from Analog 0 to ground
Connect LED from pin 11 through a resistor to ground
For more information see www.ladyada.net/learn/sensors/cds.html */
#include <Wire.h>; //IC2 communication
int photocellPin = 0; // the cell and 10K pulldown are connected to a0
int photodiode; // the analog reading from the sensor divider
int LEDpin = 11; // connect Red LED to pin 11 (PWM pin)
int LEDbrightness; //
int LEDbrightnessinv;
// Define the number of samples to keep track of. The higher the number,
// the more the readings will be smoothed, but the slower the output will
// respond to the input. Using a constant rather than a normal variable lets
// use this value to determine the size of the readings array.
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
volatile int NbTopsFan; //measuring the rising edges of the signal
int calc;
int hallsensor = 2; //The pin location of the sensor
void rpm () //This is the function that the interupt calls
NbTopsFan++; //This function measures the rising and falling edge of the hall effect sensors signal
void setup() {
// We'll send debugging information via the Serial monitor
Serial.begin(9600);
Wire.begin(9); // join i2c bus with address #9
Wire.onRequest(requestEvent); // register event
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
//flow setup
pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
Serial.begin(9600); //This is the setup function where the serial port is initialised,
attachInterrupt(0, rpm, RISING); //and the interrupt is attached
void loop() {
photodiode = analogRead(photocellPin);
LEDbrightness = map(photodiode, 0, 1023, 0, 255);
total= total - readings[index]; // subtract the last reading:
readings[index] = LEDbrightness; // read from the sensor:
total= total + readings[index]; // add the reading to the total:
index = index + 1; // advance to the next position in the array:
if (index >= numReadings) // if we're at the end of the array...
index = 0; // ...wrap around to the beginning:
average = total / numReadings; // calculate the average:
Serial.print("Average byte reading = ");
Serial.println(average); // send it to the computer as ASCII digits
//flow calculations
NbTopsFan = 0; //Set NbTops to 0 ready for calculations
sei(); //Enables interrupts
delay (1000); //Wait 1 second
cli(); //Disable interrupts
calc = (NbTopsFan * 60 / 7.5); //(Pulse frequency x 60) / 7.5Q, = flow rate in L/hour
Serial.print (calc, DEC); //Prints the number calculated above
Serial.print (" L/hour\r\n"); //Prints "L/hour" and returns a new line
void requestEvent()
delay(500);
Wire.send(average); //send info on light reading(may need to be LEDbrightness to keep under 255)
Wire.send(calc); //send info on flow meter
