Skimmer stop on high ato
Posted: Fri Jan 02, 2015 1:31 pm
by pandimus
Was thinking about using this code to turn off skimmer when float switch in cup is triggered
if(ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.On(Port2);
Only problem I have is if I pull off cup to clean and empty will it turn that relay back on?
If so how can I code it to keep it off till after my cup is cleaned?
Re: Skimmer stop on high ato
Posted: Fri Jan 02, 2015 3:56 pm
Change Off to Override(Port2, 0);
Posted: Fri Jan 02, 2015 3:57 pm
You may be able to MaskOff(Port2); if your on the dev code and if I added the function
Posted: Fri Jan 02, 2015 5:06 pm
by pandimus
Thanks.. I'll try override first
Posted: Fri Jan 02, 2015 5:40 pm
Good plan. I still need to add those functions :)
