Page 1 of 2
RA not found on COM5
Posted: Sat Dec 24, 2011 10:30 am
by ahmedess
recently I upgraded from reef angel controller versioon 0.8.3.1 to version 0.8.3.11. I uninstalled the old one then i restarted and installed the new one. after I ve done that I was unable to communicate with my board using the ftdi cable. I had the ftdi cable installed successfully and the serial port is set to COM5. Even during installation when i came to the step where it asks you to connect the ftdi cable to the RA it kept saying RA not found.
I tried uploading code to the RA and this is what I got:
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b57600 -D -Uflash:w:C:\Users\Ahmed\AppData\Local\Temp\build2361283832433358734.tmp\RA_122411_1909.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         Using Port            : \\.\COM5
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 57600
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank yo
I m using hte old bootloader. Any clues how to fix this?
Re: RA not found on COM5
Posted: Sat Dec 24, 2011 11:00 am
What "board" is selected under "Tools --> Board"?
Is the "ReefAngel Controller w/ Optiboot" selected?
In the newer versions, the default is the "Optiboot" board. You should change that back to just be "ReefAngel Controller". Then try to communicate.
Posted: Sat Dec 24, 2011 11:02 am
by ahmedess
done that same error.
Posted: Sat Dec 24, 2011 11:05 am
Do you have RAGen installed? If you do, I would suggest running the "Find Controller" and see if it can detect the controller.
Posted: Sat Dec 24, 2011 11:06 am
by ahmedess
I also tried to reinstall the old version of reef angel controller 0.8.13.1 and I still couldnt get the RA to communicate with the PC. I tried the RAgen test also it says COM5 - none
Posted: Sat Dec 24, 2011 11:13 am
by ahmedess
I thinking about upgrading to optiboot now I have the programmer. but i m worried cause i currently have the RA running on my tank if I upgrade the bootloader then I will have to reload my code. if upgrading the bootloader wont fix the problem then I wont be able to use my RA on my tank unless i figure a solution to the problem.
Posted: Sat Dec 24, 2011 11:22 am
by ahmedess
i kept trying to upload several times until it actually uploaded successfully, what does that mean?
Posted: Sat Dec 24, 2011 11:31 am
Hmm...I'm not sure about that one.
Posted: Sat Dec 24, 2011 11:37 am
by ahmedess
now i connected my programmer to the board its an AVRISP and I m trying to burn the new bootloader using the instructions on the RA website and I m getting the same error again
Posted: Sat Dec 24, 2011 11:41 am
What is the error you are getting?
Posted: Sat Dec 24, 2011 11:45 am
by ahmedess
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM15 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
Using Port : \\.\COM15
avrdude: Recv:
avrdude: Recv:
avrdude done. Thank you
Posted: Sat Dec 24, 2011 11:50 am
by ahmedess
is it related to the file boards.txt? because now i m running RA controller version 0.8.13.11 which is the latest version which has the boards.txt already edited
Posted: Sat Dec 24, 2011 11:52 am
If you are trying to burn the new bootloader, you are not doing it correctly.
You should go to menu Tools-> Burn Bootloader -> w/AVR ISP.
If you are trying to upload and you are getting this error, most likely is because something went slightly not accordingly when updating the drivers.
Please go to Control Panel->System->Device Manager
Then expand "Ports (COM & LPT)" and double-click the "USB Serial Port (COM15)"
Click tab "Port Settings" and click "Advanced" button
Make sure that checkbox "Set RTS on Close" is checked and click "OK" on all opened windows.
Posted: Sat Dec 24, 2011 11:56 am
by ahmedess
thats what I m exactly doing. Also I have RTS on Close checked and I m still getting the same error
I have aurdino open i goto menu Tools-> Burn Bootloader -> w/AVR ISP and I get the error posted before
Posted: Sat Dec 24, 2011 12:11 pm
Are you using a modified AVR chip as AVR ISP or you have a real programmer?
If you have the real programmer, you need to go with "w/ AVRISP mkII"
Posted: Sat Dec 24, 2011 12:15 pm
by ahmedess
I have this programmer AVR AVRISP V2.0 STK500 USB ISP
http://ram-e-shop.com/oscmax/catalog/pr ... ts_id=1464
Posted: Sat Dec 24, 2011 12:41 pm
by ahmedess
I tried the avrisp mkII it said usb device not found
Posted: Sat Dec 24, 2011 3:42 pm
I've never used AVRISP, but there are some posts that mention wrong drivers.
What do you have on your device manager list?
More ifo:
http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1228502992
Posted: Sat Dec 24, 2011 3:51 pm
by ahmedess
some ppl on this link http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1228502992
were having the same problem that i m having.
Quoted from Mark in Arduino forums from the link above
"Are you sure it is a MKII or is it a v2 ?
Today I received from a HK company (via eBay) a STK500 USB clone.
It uses an USB serial chip to make it look like a com port. It took me about an hour to figure out what was going on because it arrived with ZERO documentation.
I determined that I had to edit the boards.txt file and add these lines:
avrisp.name=HK-AVR ISPv2
avrisp.communication=serial
avrisp.protocol=stk500v2
Do an eBay search for "ATMEL STK500 Programmer for Arduino & Freeduino Board" to see what I got.
FYI: Switch 1 should be off, Switch 2 should be ON."
I have added the three lines above to teh file programmer.txt in the arduino directory. but i do not understand what he means by switch 1 should be off and switch 2 should be on
Posted: Sat Dec 24, 2011 3:54 pm
I think he means a dip switch. Does yours have a dip switch in it? You may need to open the case.
Posted: Sat Dec 24, 2011 3:58 pm
by ahmedess
rimai wrote:I've never used AVRISP, but there are some posts that mention wrong drivers.
More ifo:
Thats the same link I was reading. in device manager I have the device named " USB serial port (COM15)" and the driver is FTDI
Posted: Sat Dec 24, 2011 3:59 pm
Isn't that your USB-TTL cable?
Posted: Sat Dec 24, 2011 4:06 pm
by ahmedess
nope my usb ttl cable is COM5
Posted: Sat Dec 24, 2011 4:07 pm
by ahmedess
i opened the programmer and there were no switches at all inside.
Posted: Sat Dec 24, 2011 4:18 pm
Ok, if COM15 is your programmer, we can say for sure that you should not use "w/ AVRISP mkII".
It should be "w/ AVRISP" indeed.
Posted: Sat Dec 24, 2011 4:46 pm
by ahmedess
ok what about the stk500 should i choose v1 or v2? I have tried V1 and it kept giving me this error:
avrdude: Recv:
avrdude: Recv:
also I keep getting this error "avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51" alot during uploading code using the TTL usb cable. I have to keep trying by unplugging the usb plug from the pc and plugging it back in while the RA is connected to the cable. it used to happen once in a while before but now it happens a lot. I thought it might be related to the upgrade i made to the RA controller files but then i reverted to the old RA controller installer version 0.8.13.1 and i still get this error. sometimes it uploads normally and sometimes it just keeps bugging me with this error. but for the programmer case i kept trying several times with the AVRISP programmer choice in arduino but it never went through. do you think these two errors might be related?
Posted: Sat Dec 24, 2011 4:58 pm
I don't think they are related and according to the post, you should use v2 for the programmer
Posted: Sun Dec 25, 2011 10:43 am
by ahmedess
it worked! at last. thank you for your support. Now I have optiboot bootloader. I m trying to upload the internal memory PDE and I keep getting the error :
Binary sketch size: 7194 bytes (of a 32256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\Ahmed\AppData\Local\Temp\build3707626226319611616.tmp\Memory_060111_0150.cpp.hex:i
         Overriding Baud Rate  : 115200
avrdude: Recv:
avrdude: Recv:
avrdude done.  Thank you.
I tested the COM port using ragen find controller option and it found the controller but i m unable to upload sketches
the red LED now is blinking 3 times then off for a sec then blinks again continuously
Posted: Sun Dec 25, 2011 11:29 am
by ahmedess
okay here is what i found. when i chose in the arduino program reef angel controller instead of reef angel w/optiboot the upload worked fine!! does that mean the bootloader i uploaded was not optiboot? how come, i followed the instructions on this link http://forum.reefangel.com/viewtopic.php?f=2&t=113 exactly?
Posted: Sun Dec 25, 2011 11:49 am
Sorry, my fault.
I had the wrong procedure.
You need to select the Reef Angel Controller w/ optiboot under Tools->Boards, prior to burning the bootloader.
Whichever board is selected is the bootloader that will be burned.
