not seeing voltage on dimmer expansion.
Posted: Tue Feb 10, 2015 10:20 am
by pandimus
trying to get my jebao to run on dimmer expansion port 2 and 3..
why am i seeing no voltage?
    ReefAngel.FeedingModePorts = Port7Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.StandardFan( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.StandardHeater( Port6 );
    ReefAngel.DosingPumpRepeat1( Box1_Port1 );
    ReefAngel.DosingPumpRepeat2( Box1_Port2 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DCPump.ExpansionChannel[2] = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[3] = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[4] = Sync;
    ReefAngel.DCPump.ExpansionChannel[5] = Sync;
    ReefAngel.PWM.Channel0PWMSlope(40); // Starts whites 40 minutes earlier and ends 60 minutes later
    ReefAngel.PWM.Channel1PWMSlope(60); // Starts actinics 60 minutes earlier and ends 60 minutes later
    ReefAngel.Portal( "pandimus" );
    ReefAngel.DDNS( "pandimus" ); //Your DDNS is pandimus-Home.myreefangel.com
Re: not seeing voltage on dimmer expansion.
Posted: Tue Feb 10, 2015 12:53 pm
by pandimus
Nvmd.. Wiring
