Skimmer float
Posted: Wed Feb 11, 2015 8:56 am
by paperdesk
I have a float switch in my skimmer overflow container. I want my skimmer to shut off when the container gets full.
Here's my code borrowed from another forum member:
ReefAngel.Relay.overide(Port8, 0);
ReefAngel.Relay.On(Port8);
I get the following verification error: class RelayClass has no member named override
What do I need to do now?
Re: Skimmer float
Posted: Wed Feb 11, 2015 9:14 am
It's Override
Re: Skimmer float
Posted: Wed Feb 11, 2015 10:13 am
by paperdesk
Wow, that's embarrassing. Thanks
Ted
Re: Skimmer float
Posted: Wed Feb 11, 2015 10:44 am
No worries
You can find a reference to all the functions at
http://www.easte.net/RA/html
Re: Skimmer float
Posted: Wed Feb 11, 2015 11:37 am
by paperdesk
That site site looks like a goldmine!
Re: Skimmer float
Posted: Wed Feb 11, 2015 9:36 pm
by paperdesk
I need a little more help. I'm not a programmer, and though I have a real interest in learning, and am learning slowly, it's going to be a while before I get even close to where I want to be. Meanwhile, I'm having a hard time figuring out how to make this skimmer float switch work. I corrected the spelling error, but get pretty much the same message.
Re: Skimmer float
Posted: Wed Feb 11, 2015 9:44 pm
Can you post your code?
Re: Skimmer float
Posted: Thu Feb 12, 2015 3:50 am
by cosmith71
Make sure it's Override, with a capital O and two r's. In you post you have a small 'o' and one 'r'.
I know, because I stole this code last night and got the error.
Re: Skimmer float
Posted: Sun Feb 15, 2015 11:49 am
by paperdesk
I know I'm doing something wrong, though I've tried all the suggestions! Here is my code.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardFan( Port1,780,790 );
ReefAngel.StandardHeater( Port2,780,785 );
ReefAngel.Relay.DelayedOn( Port4,8 );
ReefAngel.Relay.DelayedOn( Port5,8 );
ReefAngel.SingleATO( true,Port7,3600,5 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(8,0,21,0,10,70,65,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(8,0,21,0,9,40,65,9) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(8,0,21,0,8,70,65,8) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(8,0,21,0,6,40,65,6) );
ReefAngel.DCPump.SetMode( Constant,40,10 );
ReefAngel.Relay.Override(Port8);
Re: Skimmer float
Posted: Sun Feb 15, 2015 11:53 am
by cosmith71
Should be
ReefAngel.Relay.Override(Port8,0);
Also, it might be backwards (float switches always confuse me). If it shuts off immediately, you may need to do this:
Re: Skimmer float
Posted: Sun Feb 15, 2015 11:54 am
That can't be the complete code.
It's missing stuff at the end.
And that is not including the Portal function if you use it.
Also, if you check the Override function posted above, there is a second argument to that function.
It should be Override (Port8,0) and not just Override (Port8)
So, your code should be:
Re: Skimmer float
Posted: Mon Feb 16, 2015 2:54 am
by paperdesk
Thanks a lot! I think this did it for me though I only did a quick check so far.
