No temp or Ph readout
Posted: Tue Feb 17, 2015 3:12 pm
by hodge1995
I have read some of the other post about this and couldn't solve the problem. As title says I am getting no temp or ph reading any ideas?
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="Heater2";
ReefAngel.CustomLabels[2]="ReturnPump";
ReefAngel.CustomLabels[3]="Jebao dc return";
ReefAngel.CustomLabels[4]="Skimmer";
ReefAngel.CustomLabels[5]="reactor";
ReefAngel.CustomLabels[6]="spare";
ReefAngel.CustomLabels[7]="spare";
ReefAngel.StandardHeater( Port1,765,796 );
ReefAngel.StandardHeater( Port2,755,795 );
ReefAngel.Portal( "hodge1995" );
ReefAngel.DDNS( "192.168.xxx.xx:2000" ); // Your DDNS is hodge1995-192.168.xxx.xx:2000.myreefang
Re: No temp or Ph readout
Posted: Tue Feb 17, 2015 3:58 pm
how many ph probes do you have? if you just have the main one, then you do not need the ph expansion module.
secondly, your ddns line is wrong. that ddns line should be another simple name like, "home" or "bedroom" but not the 192.168.xxx.
for the temperatures, make sure you have the temp probe plugged into one of the probe ports fully then connect the power to the reef angel. if you already have power to it, just unplug the reef angel and plug it back in. if the reef angel does not detect the probe when it powers up, then it shows error on the display. im not sure if it keeps checking for the probes, but i do know that there is error code built in that does not update the temperature if there is a spike of 10 degrees or more in a 1 second interval. there used to be problems with random jumps that would trigger events and we put in a sanity check on the temperature because the temp should not change more than 10 degrees in 1 second.
so connect the temp probe and then power cycle the reef angel.
Posted: Tue Feb 17, 2015 4:43 pm
by hodge1995
I just have one ph. I will remove this portion: ReefAngel.AddPHExpansion(); // pH Expansion Module
and will remove the :-192.168.xxx.xx:2000 portion in the ddns
On the temp I have tried plugging and unplugging power and restarting controller , I don't get any errors or anything.
Posted: Tue Feb 17, 2015 4:46 pm
Do you get ph readings without the temp probes?
Posted: Tue Feb 17, 2015 4:56 pm
by hodge1995
When I unplugged the temp probe 2.93 popped up on the ph probe and doesn't change
Posted: Tue Feb 17, 2015 5:01 pm
Looks like your probe is bad then. Possibly the pH probe too. When was the last time it read correctly?
Posted: Tue Feb 17, 2015 5:03 pm
by hodge1995
About 3 days ago all worked fine. I acquired it from a buddy. Ph probe was not allowed to dryout.
Posted: Tue Feb 17, 2015 6:14 pm
by hodge1995
ordered new probes and a salinity module we will see if that does it.
