Relay Expansion/Relay Box questions
Posted: Tue Feb 17, 2015 5:14 pm
So I am having a little bit of difficulty figuring out what hardware I will need.
My problem is my sump and where I want the RA and primary relay box is about 40 feet from my DT. So I plan on buying a Relay Expansion and a long VMA cable so I can control the lights pumps fans etc. I have LEDs and want to be able to dim them but there is no dimming port on the expansion relay box which is activated, right? If I am wrong let me know.
So I think i would have to have a dimming expansion ,which also can not connect to the relay box? If it can't then i would need an expansion hub and a very long bus cable, right? If this is the case, what bus cable would i need to find? The one which comes with the dimming exp will not be long enough.
I am not sure if i am explaining this very well so if you are willing to help and i don't make sense just ask and I will try to clarify for you. TIA
