I can't find the Wizard
Posted: Tue Feb 24, 2015 7:00 pm
by m.adamschwartz
Hey guys, I'm new to the programming on the reef angel. I've downloaded the installer and all, but when I click on the Arduino green icon i click on the drop down menu at the top under tools and I do not have a wizard to choose from. I'm using an older mac so that could be the issue but perhaps I'm missing something! I'm attaching a screen shot so perhaps that will help. I checked the version it says 1.01 I'm not sure if that makes a difference. This is the one I downloaded form the Reef Angel website under downloads for the mac. Any help would be great! Thanks guys!
Adam
Re: I can't find the Wizard
Posted: Tue Feb 24, 2015 7:09 pm
Did you move the Arduino folder inside the installer package to your documents folder?
Posted: Tue Feb 24, 2015 7:55 pm
by m.adamschwartz
I hadn't but upon doing so It does not seem to make a difference. Does this look correct?
Posted: Tue Feb 24, 2015 9:38 pm
What do you have inside the folder Documents/Arduino ?
Posted: Wed Feb 25, 2015 4:29 am
by m.adamschwartz
I checked this morning and their didn't appear to be anything.
Posted: Wed Feb 25, 2015 8:48 am
If there is nothing, it means you did not move the correct folder to the correct spot.
You will find detailed explanation of which folder to move in the user's manual, but basically you need to move the Arduino folder to the Documents folder when you open the installer package you downloaded from the website.
