Changing Daylight Channel
Posted: Mon Mar 16, 2015 4:11 pm
I would like to use the daylight channel to activate a relay. Can I change the name of the channel to Ro Shut Off? It will just have to be off or at 100 percent to activate a 5v relay.
Also my actinic channel is setup to activate the buzzer however when I use the lights on feature in the app it actives. Is there something I can change in the code? Thank you
