No I have not found the problem yet. Please have a look at the code below, it's my entire ino file.
#include <Math.h>
#include <SoftwareSerial.h>
// Port1: ATO
// Port2: Empty
// Port3: Refugium light
// Port4: Daylight
// Port5: Return pump
// Port6: Pellets pump
// Port7: Skimmer
// Port8: Heater
// Expansion 1
// Port1: Lunar
// Port2: Dimmer
// Port3: Empty
// Port4: Empty
// Port5: Mg
// Port6: Ca
// Port7: Fan
// Port8: ATO
ReefAngel.SetTemperatureUnit(Celsius); // set to Celsius Temperature
ReefAngel.AddRANet();
ReefAngel.Relay.RANetFallBackE[1] = Port3Bit;
// ReefAngel.DDNS("phrusher");
// ReefAngel.Network.WifiAuthentication("phrusher:xxxxxxxx");
ReefAngel.Use2014Screen();
ReefAngel.Display24h();
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port7Bit | Port8Bit; // Ports toggled in Feeding Mode
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit | Port6Bit | Port8Bit; // Ports toggled in Feeding Mode
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port7Bit; // Ports toggled in Water Change Mode
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port5Bit | Port6Bit | Port8Bit; // Ports toggled in Water Change Mode
ReefAngel.OverheatShutoffPorts = Port4Bit | Port8Bit;
// Use T2 probe as temperature and overheat functions
ReefAngel.Relay.On( Port5 ); // Return
ReefAngel.Relay.On( Port8 ); // Heater
InternalMemory.OverheatTemp_write( 290 ); // Set the Overheat temperature setting
int moonphase = MoonPhase();
// Lights
ReefAngel.StandardLights( Port3, 15, 0, 7, 0 ); // Refugium
ReefAngel.StandardLights( Port4, 6, 0, 22, 00 ); // Daylight
ReefAngel.PWM.SetChannel( 0, moonphase); // Moonlight: Unmodified
ReefAngel.PWM.SetChannel( 1, PWMParabola(6,0, 20,30, 2, 85, 2) ); // Daylight: Blue
ReefAngel.PWM.SetChannel( 2, PWMParabola(7,0, 19,30, 2, 65, 0) ); // Daylight: White
ReefAngel.PWM.SetChannel( 4, 30 ); // Refugium light
ReefAngel.PWM.SetChannel( 5, 100 - PWMParabola(21,0, 7,0, 94, 99, 94) ); // Moonlight
// Dosing
ReefAngel.DosingPump( Box1_Port5, 1, 7, 00, 4 ); // 0.75 ml/sec Mg
ReefAngel.DosingPump( Box1_Port5, 1, 22, 00, 4 ); // 0.75 ml/sec Mg
ReefAngel.DosingPump( Box1_Port6, 2, 7, 01, 5 ); // 0.75 ml/sec Ca
ReefAngel.DosingPump( Box1_Port6, 2, 22, 01, 5 ); // 0.75 ml/sec Ca
// ATO
ReefAngel.WaterLevelATO( Port1, 20, 75, 80 );
if(ReefAngel.Params.Temp[T2_PROBE] > 260){
ReefAngel.Relay.Off( Port8 ); // Heater
} else {
ReefAngel.Relay.DelayedOn (Port7, 2); // Delay skimmer 2 minutes after feeding
if ((hour() == 8 || hour() == 18) && minute() == 55 && second() == 0)
ReefAngel.FeedingModeStart();
if (ReefAngel.DisplayedMenu == FEEDING_MODE)
ReefAngel.PWM.SetDaylight( LongPulseMode(35, 45, 30, true ));
ReefAngel.PWM.SetActinic( LongPulseMode(35, 45, 30, false));
else if(ReefAngel.DisplayedMenu == WATERCHANGE_MODE)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if ((hour() == 9 || hour() == 19) && minute() <= 20)
WaveMakerSyncMillis(383, 75, 0); // After Feeding
else if (hour() >= 21 || hour() <= 6)
// Night mode
ReefAngel.PWM.SetDaylight( LongPulseMode(38, 50, 30, true ));
ReefAngel.PWM.SetActinic( LongPulseMode(38, 50, 30, false));
if(hour() >= 8 && hour() <= 19) {
if (minute() % 10 == 0) {
ReefAngel.PWM.SetDaylight( LongPulseMode(40, 85, 30, true )); // LongPulseMode at 40%, 85% 30s on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(40, 85, 30, false)); // LongPulseMode at 40%, 85% 30s on anti-sync mode
} else if (hour() >= 10 && hour() <= 16) {
ReefAngel.PWM.SetDaylight( ElseMode(80, 20, true )); // ElseMode at 80% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ElseMode(80, 20, false)); // ElseMode at 80% +/- 20% on anti-sync mode
} else {
ReefAngel.PWM.SetDaylight( ReefCrestMode(70, 15, true )); // ReefCrest at 70% +/- 15% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(70, 15, false)); // ReefCrest at 70% +/- 15% on anti-sync mode
} else {
ReefAngel.PWM.SetDaylight( LongPulseMode(40, 70, 60, true )); // LongPulseMode at 40%, 70% 60s on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(40, 70, 60, false)); // LongPulseMode at 40%, 70% 60s on anti-sync mode
ReefAngel.Portal( "phrusher" );
// Wavemaker
/** Calculates the tidal flow.
* Ex. hour => flow
* 0 => 0 6 => 6 12 => 0 18 => 6
* 1 => 1 7 => 5 13 => 1 19 => 5
* 2 => 2 8 => 4 14 => 2 20 => 4
* 3 => 3 9 => 3 15 => 3 21 => 3
* 4 => 4 10 => 2 16 => 4 22 => 2
* 5 => 5 11 => 1 17 => 5 23 => 1
* \param hour: Hour in 24h format to calculate flow from
* \returns flow value
int flow(int hour)
return (((hour/6) % 2) == 0 ? hour % 6 : 6 - hour % 6);
int pulsePower(int pulse, int maxPower, int minPower)
return (millis()%(pulse*2))<pulse ? maxPower : minPower;
/** Basic tidal simulation by gradually changing the opposing flow four times during 24h.
* By setting duration of opposing pumps it creates a directional flow in the tank that changes during one day.
* Ex. hour => pump01 : pump02 (duration in seconds)
* 0 => 2 : 14 6 => 14 : 2 12 => 2 : 14 18 => 14 : 2
* 1 => 4 : 12 7 => 12 : 4 13 => 4 : 12 19 => 12 : 4
* 2 => 6 : 10 8 => 10 : 6 14 => 6 : 10 20 => 10 : 6
* 3 => 8 : 8 9 => 8 : 8 15 => 8 : 8 21 => 8 : 8
* 4 => 10 : 6 10 => 6 : 10 16 => 10 : 6 22 => 6 : 10
* 5 => 12 : 4 11 => 4 : 12 17 => 12 : 4 23 => 4 : 12
* \param maxPower: The maximum pump power
* \param minPower: The minimum pump power
* \param pause: Length of the pause between each interval. Negative pause becomes overlap.
void WaveMakerTidal(int maxPower, int minPower, int pause)
static boolean state = true;
static unsigned long nexttoggle=now();
long cycle=nexttoggle-now();
int pulse = 373;
if (cycle<0)
int duration = flow( hour() ) << 1; // 0 - 12
//int duration = flow( hour()); // 0 - 6
nexttoggle = now() + (state ? duration : (12-duration)) + 2 + pause; // flow->counter flow => 2->14
state = !state;
if (pause > 0 && cycle < pause)
else if (pause < 0 && cycle < pause)
ReefAngel.PWM.SetActinic(maxPower);
ReefAngel.PWM.SetDaylight(maxPower);
//int power = (millis()%(pulse*2))<pulse ? maxPower : minPower;
int power = pulsePower(pulse, maxPower, minPower);
if(state){
ReefAngel.PWM.SetActinic(power);
else {
ReefAngel.PWM.SetDaylight(power);
/** Toggles opposing pumps with a pause between each interval.
* \param power: The pump power
* \param duration: Duration of each interval
* \param pause: Length of the pause between each interval. If pause is negative it will work as an overlap.
void WaveMakerPause(int power, int duration, int pause)
if (cycle<0)
nexttoggle = now() + duration;
state = !state;
else if(pause < 0 && cycle < pause)
else {
if(state){
else {
void WaveMakerSyncMillis(long duration, int maxPower, int minPower)
if ((millis()%(duration*2))<duration)
ReefAngel.PWM.SetActinic(minPower);
ReefAngel.PWM.SetDaylight(minPower);
else {
