Define ports by name?
Posted: Fri Mar 20, 2015 6:14 pm
by ewaldsreef
If you define ports by name what does this do exactly?
Does it show up on the app or portal?
Can you Define all of the ports such as the temp, float switch, pwm etc?
Re: Define ports by name?
Posted: Fri Mar 20, 2015 11:00 pm
by Sacohen
Defining port names in your code like this...
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Kalkwasser         3
#define Pumps              4
#define Unused             5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Main_RODI        Box1_Port7
#define Dummy              Box1_Port8
makes it easier to identify which port is doing what in the code.
To have it show up in the App or the Portal it has to be done in the labels section of the Portal and then the App can pull the names from the Portal or you can set them up in the App to under the settings section.
Posted: Sun Mar 22, 2015 10:11 pm
by ewaldsreef
Thank you Steve.
Can I also define temp probes by name?
Posted: Mon Mar 23, 2015 4:59 am
by Sacohen
I'm not sure you can on the code.
Check lnevo's code. If it can be done I'm sire he has done it.
Posted: Mon Mar 23, 2015 5:28 am
Yeah.
#define T1_PROBE DisplayTemp
Posted: Mon Mar 23, 2015 3:37 pm
Wouldnt it be the other way around roberto?
Posted: Mon Mar 23, 2015 4:40 pm
by Smotz
I have mine like this - does it matter?
#define Heater Port1
#define Topoff Port2
#define Feeder Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define Fan  Box1_Port8
#define CalcDose  Box1_Port1
#define AlkDose  Box1_Port2
Sacohen wrote:Defining port names in your code like this...
#define Pumps              4
#define Unused             5
#define ATO_Pump           8
Posted: Mon Mar 23, 2015 4:46 pm
by Sacohen
I guess it doesn't as long as it work.
I guess yours works too.
Posted: Mon Mar 23, 2015 6:12 pm
lnevo wrote:Wouldnt it be the other way around roberto?
Yes, the other way around... :oops:
Posted: Tue Mar 24, 2015 6:12 am
by cosmith71
Smotz wrote:I have mine like this - does it matter?
#define Wave Port6
It should work out the same. The libraries define Port1 as 1, Port2 as 2, etc. Steve's version just cuts out a step.
Posted: Tue Mar 24, 2015 7:17 pm
by ewaldsreef
So does this work?
#define Return             1
#define Actinic            2
#define Daylight           3
#define Skimmer            4
#define Vortechs           5
#define Heater             6
#define Ozone              7
#define Fan                8
#define Return             Box1_Port1
#define Actinic            Box1_Port2
#define Daylight           Box1_Port3
#define Skimmer            Box1_Port4
#define Vortech            Box1_Port5
#define Heater             Box1_Port6
#define Ozone              Box1_Port7
#define SumpTemp           T1_PROBE
#define AmbientTemp        T1_PROBE
#define FragTemp           T1_PROBE
Posted: Tue Mar 24, 2015 8:06 pm
You have to change the number of the probes. They are all assigned to T1
Posted: Wed Mar 25, 2015 9:45 pm
by ewaldsreef
Oops
Posted: Tue May 26, 2015 7:50 pm
by Maze531
i am looking to do this for mine as well. I am still new to this do I just write this in the text box and load it to the controller? It wont affect the current code that I have written?
Posted: Mon Jun 01, 2015 7:20 am
by cosmith71
Maze531 wrote:i am looking to do this for mine as well. I am still new to this do I just write this in the text box and load it to the controller? It wont affect the current code that I have written?
Yes. It goes right under this line in the code.
It won't affect anything. In fact, you'd need to change your current code by changing all the Port1's to Return, for example, for it to make any difference.
Posted: Mon Jun 01, 2015 9:18 am
by Maze531
thank you very much I think i have it all figured out now.
