wifi utility
Posted: Thu Apr 09, 2015 8:36 pm
by Reefology
where do i find it?
Re: wifi utility
Posted: Fri Apr 10, 2015 4:38 am
by cosmith71
It's in the ReefAngel software. After you install the RA software, it shows up on your desktop.
Re: wifi utility
Posted: Fri Apr 10, 2015 6:14 pm
by Reefology
i get this message in the portal???
Only available with valid wifi address. Please make sure your controller is sending data to the Portal web server.
how do i set this up correctly? i reecently moved and now cant get this working?!
Re: wifi utility
Posted: Sat Apr 11, 2015 4:35 am
by AlanM
Reefology wrote:i get this message in the portal???
Do the lights on the wifi attachment blink green on and off? If so, then it is on your network and you should be able to get to it from your web browser. Check out your router's config page to see the Reef Angel IP address and then go to:
http://192.168.1.5:2000/r99
or whatever IP address yours is at with port 2000 after it like in the line above.
Can you see it inside your house from the browser?
Once you know you can see it inside you can then set up port forwarding on the new router to forward any outside port to port 2000 on your router inside. Every router differs in config, but most make it pretty easy these days. Once that's done the portal will see it within 5 minutes or so if you have your forum username of Reefology in the correct ReefAngel.Portal("Reefology"); statement in your .ino file.
Re: wifi utility
Posted: Sun Apr 12, 2015 10:32 am
by Reefology
Thanks for the help but still not working.
Yes
yes and have set up port forwarding as i did before the move.
still not seeing my reefangel??? Im using the same ino???
Re: wifi utility
Posted: Sun Apr 12, 2015 10:36 am
by Reefology
also portal is updating as of yesterday at 7 pm and i have been traveling for the past couple days and just returned home so im not sure what changed without my input/tinkering??? how is that even possible? unless i have a ghost hovering around
Re: wifi utility
Posted: Sun Apr 12, 2015 12:34 pm
When you do a port check, does it show open?
Sent from my Galaxy S5 with Tapatalk
Re: wifi utility
Posted: Mon Apr 13, 2015 9:14 pm
by Reefology
No port 2000 is closed when I use current IP address. Should I be testing the internal IP address assigned to the reef Angel? That's closed also? How do I fix it?
Re: wifi utility
Posted: Mon Apr 13, 2015 9:16 pm
No, you should use the ip address that it was already pre-populated.
If it shows closed, your port forwarding isn't setup correctly.
Re: wifi utility
Posted: Tue Apr 14, 2015 4:48 am
by Reefology
I got it to open last night and was working fine. Then this am it stopped working for no apparent reason. Didn't change anything?!
Re: wifi utility
Posted: Tue Apr 14, 2015 4:56 am
by Reefology
Here is my wifi status copied from my providers page
Device details:
Connection type: Wireless (802.11)
IP address: 192.168.2.24
IP address allocation: DHCP
IP address type: Private (NAT)
Hardware address: 00:06:66:21:ee:db
Status: Off
Allowed applications
ReefAngel - TCP 2000 64.228.213.80
Re: wifi utility
Posted: Tue Apr 14, 2015 8:25 am
How far away is from the router?
Have you tried to get a little bit closer to see if it is signal strength problem?
Can you access your controller using the internal ip address?
http://192.168.2.24:2000
Re: wifi utility
Posted: Tue Apr 14, 2015 1:17 pm
by AlanM
What does "Status: Off" indicate in what you posted? Does that mean that it isn't actively connected to the access point?
BTW, your .sig shows that it did connect briefly at least to the portal this morning at 6:22am. Weird that it would not work now.
Re: wifi utility
Posted: Wed Nov 02, 2016 6:36 am
by Reefology
Hi all,
I pulled my reef angel out after a being in a box for over a year...time to finally set up a new reef after moving
Having 2 issues related to wifi.
1. Can't communicate with portal
Wifi attachment is slow blinking green and I port forwarded 2000 to the internal ip assigned to reef angel.
2. The major issue...after uploading wifi test code to solve wifi issue, I now can't upload anything else
the code I had installed worked great when I turned on the unit but now get a timeout message saying avrdude:stk500v2_command(): failed miserably to execute 0x11
I primarily want my code back and then will deal with wifi.
Thanks in advance for the help.
Re: wifi utility
Posted: Wed Nov 02, 2016 3:48 pm
by Reefology
Ok now able to upload sketches but still having trouble with the wifi attachment. It's slow blinking green and I see it on my router but not able to communicate with the portal. How do I know if I have set up port forwarding correctly?
Here's my router info:
Host Name IP Address MAC Address type Interface Status
ReefAngelWifi 192.168.0.34 00:06:66:21:EE:DB DHCP-Reserved 2.4Ghz
Active
Port Forwarding Rules
Application Name Public Private Protocol Local IP Address Remote IP Address Status Manage
Reef 2000~2000 2000~2000 TCP 192.168.0.34 Any ON OFF Manage
Re: wifi utility
Posted: Wed Nov 02, 2016 3:50 pm
Cool.
Do you have 2 routers?
One from internet and one for wifi?
Re: wifi utility
Posted: Wed Nov 02, 2016 4:25 pm
by Reefology
Thanks Roberto. No just one, why?
Re: wifi utility
Posted: Wed Nov 02, 2016 6:12 pm
If you had two, you would need port forwarding on both of them.
