Adjustments using Controller
Posted: Mon Apr 20, 2015 12:58 pm
by randynixon74
I'm having some trouble making adjustments using the controller menus and joystick. As I understand it, left and right change screens and up/down + joystick press makes changes. I'm not able to change anything. When I press the joystick in, I get the same menu list. Am I doing something wrong?
Re: Adjustments using Controller
Posted: Mon Apr 20, 2015 5:46 pm
by binder
what are you trying to change?
Sent from my Moto X
Posted: Tue Apr 21, 2015 5:54 am
by randynixon74
Really anything. It's like the menus are read-only. I was trying to change (override) the dimming settings initially, but then expanded to trying to change anything when that didn't work.
Posted: Tue Apr 21, 2015 6:45 am
by cosmith71
When you push the joystick in you will get the menu of things you can change. You cannot change things on the status pages. They are informational only.
Posted: Tue Apr 21, 2015 10:12 am
by binder
the values are really not changeable via the joystick. that functionality requires a lot of extra code on the controller and was just not feasible. it was much easier to handle value changing from the different apps instead.
Posted: Wed Apr 22, 2015 9:22 am
by randynixon74
Thanks, exactly what I needed to know.
