Water level expansion not holding
Posted: Fri May 01, 2015 11:23 pm
Hi,
I've attached multi water level expansion to my RA, and the problem is that it does not hold the values. I've calibrated the water levels for all the tubes and at first they are showing normally ~70 percent and after couple of hours it goes down to 0 percent. I've tried to put tube in still water - it holds the level, but in moving water (sump for example) it is not holding. Any suggestions?
