ReefAngel.CustomLabels causing reboot loop
Posted: Mon May 04, 2015 8:52 pm
by joshlawless
I've been tinkering with code and uploading it all day. Last night, including this code in the setup() function caused no problems:
    ReefAngel.CustomLabels[0]="Heater1";
    ReefAngel.CustomLabels[1]="Heater2";
    ReefAngel.CustomLabels[2]="Skimmer";
    ReefAngel.CustomLabels[3]="Neck Wipe";
    ReefAngel.CustomLabels[4]="Refugium Light";
    ReefAngel.CustomLabels[5]="Filters";
    ReefAngel.CustomLabels[6]="Air Pump";
    ReefAngel.CustomLabels[7]="Ozone";
    ReefAngel.CustomLabels[8]="Diverter";
    ReefAngel.CustomLabels[9]="Circulation";
    ReefAngel.CustomLabels[10]="Kalk Stirrer";
    ReefAngel.CustomLabels[11]="ATO  Pump";
Adding two more lines:
    ReefAngel.CustomLabels[12]="Return Left";
    ReefAngel.CustomLabels[11]="Return Right";
Caused it to go into a reboot loop.
I eventually located the problem in this block by commenting the whole thing out. I cleverly noticed that I had two [11]s in there, and fixed the last line:
    ReefAngel.CustomLabels[13]="Return Right";
Still with the rebooting.
I tried commenting out various lines, to see if removing the last two (or three, or four) lines would allow it to work. Still kept rebooting.
Starting at the top, and uncommenting one line with every upload, I eventually narrowed the problem down to one line.
Uploading this code lets the controller work normally.
//  ReefAngel.CustomLabels[9]="Circulation";
Uncommenting the line for [9] and uploading causes an endless reboot cycle.
Any thoughts? I don't see a problem with that line.
Re: ReefAngel.CustomLabels causing reboot loop
Posted: Mon May 04, 2015 8:53 pm
by joshlawless
Curiously, this works:
    ReefAngel.CustomLabels[9]="Movement";
Posted: Mon May 04, 2015 8:55 pm
by joshlawless
"Circ" and "Circulate" work, too. Problem seems to be with "Circulation".
Posted: Mon May 04, 2015 8:57 pm
by joshlawless
Although it doesn't like "Closed Loop" either -- reboot loop with that label, too. What the hey?
Posted: Thu Sep 10, 2015 8:42 pm
by joshlawless
I tried re-introducing custom labels into my code, and ran into the reboot loop again. Here's the offending section:
    ReefAngel.CustomLabels[0]="300W Heat";
    ReefAngel.CustomLabels[1]="100W Heat";
    ReefAngel.CustomLabels[4]="Air Pump";
    ReefAngel.CustomLabels[6]="Refuge Lt";
    ReefAngel.CustomLabels[9]="Circ Pump";
    ReefAngel.CustomLabels[10]="Kalk Stir";
    ReefAngel.CustomLabels[12]="Return L";
    ReefAngel.CustomLabels[13]="Return R";
    ReefAngel.CustomLabels[14]="200W Heat";
    ReefAngel.CustomLabels[15]="Refuge Circ";
which, when commented out, stops the reboot loop.
Here's the full code:
#include <Moon.h>
#define Heater_300W           Port1
#define Heater_100W           Port2
#define Skimmer               Port3
#define Neck_Wipe             Port4
#define Air_Pump              Port5
#define Filter_Pump           Port6
#define Refuge_Light          Port7
#define Ozone_Gen             Port8
#define FlowWolf              Box1_Port1
#define Closed_Loop           Box1_Port2
#define Kalk_Stirrer          Box1_Port3
#define ATO_Pump              Box1_Port4
#define Return_Pump_L         Box1_Port5
#define Return_Pump_R         Box1_Port6
#define Heater_200W           Box1_Port7
#define Refugium_Pump         Box1_Port8
#define Neutral_White_Center  0
#define Warm_White_Center     1
#define Royal_Blue_Center     2
#define Cool_Blue_Center      3
#define Cyan_Center           4
#define Red_Center            5
#define Indigo_Center         6
#define Violet_Center         7
int MoonBlueLevel=0;
int SunBlueLevel=0;
int SunIndigoLevel=0;
int MoonIndigoLevel=0;
    ReefAngel.Init();
    ReefAngel.AddStandardMenu();
    ReefAngel.Use2014Screen();
    ReefAngel.AddSalinityExpansion();
    ReefAngel.AddORPExpansion();
    ReefAngel.AddWaterLevelExpansion();
    ReefAngel.Add16ChPWM();
    ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port3Bit;                 // Skimmer
    ReefAngel.WaterChangePortsE[0] = Port4Bit | Port8Bit;  // ATO Pump and Refugium Circulation
    ReefAngel.OverheatShutoffPortsE[0] = Port7Bit;
    ReefAngel.DCPump.FeedingSpeed = 0;
    ReefAngel.DCPump.WaterChangeSpeed = 0;
    ReefAngel.Relay.On( Air_Pump );
    ReefAngel.Relay.On( Filter_Pump );
    ReefAngel.Relay.On( FlowWolf );
    ReefAngel.Relay.On( Closed_Loop );
    ReefAngel.Relay.On( Return_Pump_L );
    ReefAngel.Relay.On( Return_Pump_R );
    ReefAngel.Relay.On( Refugium_Pump );
    if ( ReefAngel.Params.Temp[T1_PROBE] < 775 ) ReefAngel.Relay.On( Heater_300W );
    if ( ReefAngel.Params.Temp[T1_PROBE] > 780 ) ReefAngel.Relay.Off( Heater_300W );
    if ( ReefAngel.Params.Temp[T2_PROBE] < 775 ) ReefAngel.Relay.On( Heater_100W );
    if ( ReefAngel.Params.Temp[T2_PROBE] > 780 ) ReefAngel.Relay.Off( Heater_100W );
    if ( ReefAngel.Params.Temp[T3_PROBE] < 775 ) ReefAngel.Relay.On( Heater_200W );
    if ( ReefAngel.Params.Temp[T3_PROBE] > 780 ) ReefAngel.Relay.Off( Heater_200W );
    ReefAngel.DCPump.Threshold = 80;
    ReefAngel.DCPump.SetMode( Sine, 100, 240 );
    moon_init(44,-116);   // approximate lat,lon for Boise, ID
    SunBlueLevel = PWMSmoothRampHighestRes( 7, 45, 22, 00, 0, 2047, 100, 0 );
    MoonBlueLevel = PWMSmoothRampHighestRes( Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 0, (int)(MoonPhase()/15), 45, 0);
    SunIndigoLevel = PWMSmoothRampHighestRes( 7, 35, 22, 10, 0, 620, 100, 0 ) ; // 10 minute longer
    MoonIndigoLevel = PWMSmoothRampHighestRes( Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 0, (int)(MoonPhase()/30), 45, 0);
    ReefAngel.PWM.Set16ChannelRaw( Neutral_White_Center, PWMSmoothRampHighestRes( 7, 45, 22, 00, 0, 1532, 100, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Warm_White_Center,    PWMSmoothRampHighestRes( 7, 45, 22, 00, 0, 1532, 100, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Royal_Blue_Center,    max (SunBlueLevel, MoonBlueLevel) );
    ReefAngel.PWM.Set16ChannelRaw( Cool_Blue_Center,     PWMSmoothRampHighestRes( 7, 45, 22, 00, 0, 1280, 100, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Cyan_Center,          PWMSmoothRampHighestRes( 7, 45, 22, 00, 0, 960, 100, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Red_Center,           PWMSmoothRampHighestRes( 7, 35, 22, 10, 0, 960, 100, 0 ) ); // 10 minute longer
    ReefAngel.PWM.Set16ChannelRaw( Indigo_Center,        max (SunIndigoLevel, MoonIndigoLevel) );
    ReefAngel.PWM.Set16ChannelRaw( Violet_Center,        PWMSmoothRampHighestRes( 7, 40, 22, 05, 0, 320, 100, 0 ) ); // 05 minute longer
for (int i=0; i<8; i++)
  ReefAngel.CustomVar[i] = (int)(ReefAngel.PWM.Get16ChannelValueRaw(i)/40.95);
    ReefAngel.Relay.Set( Refuge_Light, !((hour() >= 10) && (hour() < 19)));
    pinMode(lowATOPin,OUTPUT);
    if ( (hour() >= 8) && (hour() < 22) )
      if ( now()%3600<10 ) analogWrite(lowATOPin,0);
      else if ( now()%3600 >= 10 && now()%3600<20 ) analogWrite(lowATOPin,255);
      else analogWrite(lowATOPin,128);
    else analogWrite(lowATOPin,96);
    ReefAngel.Relay.DelayedOn( Skimmer, 1 );
    if ( ReefAngel.WaterLevel.GetLevel() > 55 ) ReefAngel.Relay.Off( Skimmer );
    if ( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.Relay.Off( Skimmer );
    if ( !ReefAngel.HighATO.IsActive() ) ReefAngel.Relay.Override( Skimmer, 0 );
    ReefAngel.DosingPumpRepeat( Neck_Wipe, 0, 240, 30 );
    ReefAngel.DosingPumpRepeat( Kalk_Stirrer, 0, 240, 30 );
      ReefAngel.WaterLevelATO( ATO_Pump, 1200, 38, 40 ); // On at 38% and off at 40% with 1200 second (20 minute) timeout.
    if ( (hour() == 7 ) )
      ReefAngel.WaterLevelATO( ATO_Pump, 3601, 38, 40 ); // On at 38% and off at 40% with 3601 second (>60 minute) timeout.  Long timeout permits top-up after ATO pump overnight pause.
    if ( hour() == 22 )
      ReefAngel.WaterLevelATO( ATO_Pump, 3599, 42, 45 ); // On at 41% and off at 43% with 3699 second (<60 minute) timeout.  Long timeout and higher values ensure top-up before ATO pump overnight pause.
    else ReefAngel.Relay.Off( ATO_Pump );
    if ( ReefAngel.Params.ORP>450 || ReefAngel.Params.ORP==0 ) ReefAngel.Relay.Off( Ozone_Gen );
    if ( ReefAngel.Params.ORP<400 && ReefAngel.Params.ORP>0 ) ReefAngel.Relay.On( Ozone_Gen );
    ReefAngel.Portal( "joshlawless" );
    ReefAngel.DDNS( "reef" );
int PWMSmoothRampHighestRes(byte startHour, byte startMinute, byte endHour, byte endMinute, int startPWMint, int endPWMint, byte slopeLength, int oldValue)
  LightsOverride=true;
  int current_hour = hour();
  long current_millis = millis();
  long start = NumMins(startHour, startMinute)*600L;
  long end = NumMins(endHour, endMinute)*600L;
  long slopeLengthTenthSecs = slopeLength*600L;
  if (start > end) // Start is greater than End so it is over midnight
    if (current_hour < endHour) start -= 1440L*600L; // past midnight
    if (current_hour >= startHour) end += 1440L*600L; // before midnight
  long current = NumMins(current_hour, minute())*600L + second()*10L + (current_millis%1000 - current_millis%100)/100L;
  if (slopeLengthTenthSecs > ((end-start)/2) ) slopeLengthTenthSecs = (end-start)/2; // don't allow a slope length greater than half the total period
  if (current <= start || current >= end)
    return oldValue; // it's before the start or after the end, return the default
  { // do the slope calculation
    int pwmDelta = endPWMint - startPWMint;
    float smoothPhase;
    if ((current > (start + slopeLengthTenthSecs)) && (current < (end - slopeLengthTenthSecs)))
      return endPWMint; // if it's in the middle of the slope, return the high level
    else if ((current - start) < slopeLengthTenthSecs)
    {  // it's in the beginning slope up
      smoothPhase = (((float)(current-start)/(float)slopeLengthTenthSecs)*180.0) + 180.0;
    else if ((end - current) < slopeLengthTenthSecs)
    { // it's in the end slope down
      smoothPhase = (((float)(end-current)/(float)slopeLengthTenthSecs)*180.0) + 180.0;
    return startPWMint + (int)(pwmDelta*((1.0+(cos(radians(smoothPhase))))/2.0));
Posted: Fri Sep 11, 2015 9:11 am
Yeah, I think we will need to move those to PROGMEM.
Posted: Mon Aug 01, 2016 3:27 pm
by projectx
was there ever a solution to this? I just ran into it myself, thought it was only the 2nd page of labels. I have yet to try one at a time to see which line is the offender.
Posted: Mon Aug 01, 2016 5:09 pm
by projectx
I just played around with the code and if I put "StandLight" on port 9 it reboot loops
if I put StndLight its fine
thoughts?
ReefAngel.CustomLabels[9]="StndLight";
Posted: Mon Aug 01, 2016 8:26 pm
Yes, the solution was to move the entire custom label strings to flash memory instead of RAM.
Unfortunately, the dev branch has all the labels moved to the flash, but I forgot to implement the read from flash for the RA+ screens. I only made the change effective on the next gen RA.
I'll work on it and will let you know when it's been implemented and you can test it.
Give me a few days.
Posted: Mon Aug 01, 2016 9:56 pm
by projectx
take your time. i appreciate it
Posted: Thu Aug 04, 2016 5:33 pm
I pushed the update to the dev branch if you want to try it out.
https://github.com/reefangel/Libraries/tree/dev
Posted: Thu Aug 04, 2016 5:34 pm
Ahhh. Forgot to mention you will need to use the newest IDE.
http://forum.reefangel.com/viewtopic.php?f=7&t=5993
