Possible bad float switch
Posted: Tue May 12, 2015 11:13 pm
by MDB1029
The float switch I was using as my ATO seems to have stopped working properly. I replaced it with the other and the ATO resumed normal function. I was wondering if there was a way to test if the switch was working properly or not since i have another use for the second switch?
Re: Possible bad float switch
Posted: Wed May 13, 2015 12:09 am
by pandimus
Multimeter? Check continuity on both leads with switch in both positions
