Feeding mode using Memory
Posted: Fri May 29, 2015 2:12 pm
by Rodasphoto
How do I code a feeding mode that turns my main pump and RW8 off and turns on my feeder (http://www.super-feed.com/product.html) for a minute or so. I would like to be able to adjust the time of when the mode initiates and number of times using the memory input in android app. Later on when I get the right cable I would like my RW8 to initiate nutrient transport mode when finished with feeding mode then go back to what ever mode I had previously. Many thanks for your help.
Main Relay
1. Skimmer
2. LED fan
3. LED power supply 1
4. LED power supply 2
5. RW8
6. MJ1200 water mixing station
7. Heater
8. DC3000
Expansion Relay 1
1. ATO
2. Not Used
3. Not Used
4. Not Used
5. Autowater change 1
6. Autowater change 2
7. Not Used
8. Not Used
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port4Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port7Bit;
    ReefAngel.DayLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.DayLights( Port5 );
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DayLights( Box1_Port1 );
    ReefAngel.PWM.Channel0PWMParabola();
    ReefAngel.PWM.Channel1PWMParabola();
    ReefAngel.PWM.Channel2PWMParabola();
    ReefAngel.PWM.Channel3PWMParabola();
    ReefAngel.PWM.Channel4PWMParabola();
    ReefAngel.PWM.Channel5PWMParabola();
    ReefAngel.Relay.On( Box1_Port1 ); // ATO port is always on
    ReefAngel.DosingPumpRepeat1(Box1_Port6); // AWC change 2 (add)
    ReefAngel.DosingPumpRepeat2(Box1_Port5); // AWC change 1 (drain)
    ReefAngel.Portal( "Rodasphoto" );
Re: Feeding mode using Memory
Posted: Sat May 30, 2015 9:02 am
It looks like you already have the pumps being turned off during feeding mode.
Are you wanting to create a completely separate feeding mode (like feeding mode 2 or alternate feeding mode)?
Posted: Sat May 30, 2015 1:15 pm
by Rodasphoto
binder wrote:It looks like you already have the pumps being turned off during feeding mode.
No I just want to be able to enter feeding mode automatically and trigger my feeder. I would need for it to be on for a minute or so. Right now I would only need this to happen once a day or every other day. When I get my trio of anthias it will need to occur 3 times a day.
Posted: Sat May 30, 2015 2:17 pm
Here are 2 posts that will be doing exactly what you want:
http://forum.reefangel.com/viewtopic.ph ... lly#p43169
http://forum.reefangel.com/viewtopic.ph ... lly#p41920
They both trigger feeding mode based on a specific time of day. The first one shows how to activate feeding mode at 2 different times of day. The concept for it should be straight forward once you see it.
To address your comment about only running feeding mode for a minute or so, you would need to change the "Feeding Mode Timer" value from 900 seconds (which is 15 minutes) down to 60 seconds (for 1 minute) or whatever duration you want it to be.
Posted: Tue Jun 02, 2015 2:06 pm
by Rodasphoto
if (ReefAngel.Relay.isMaskOn(Box1_Port8))
if (ReefAngel.DisplayedMenu!=FEEDING_MODE) feedStart=false; // Reset the flag...
if (ReefAngel.DisplayedMenu==FEEDING_MODE && feedStart==false) {
  feedStart=true; // So we don't start the timer more than once per feeding mode.
  feedTimer=now(); // We're going to use this time to see if 2 minutes is up before we trigger the feeder.
if ( now()-feedTimer == 120) // 2 min later activate auto feeder
// Start feed mode once per day at 12pm.
if (hour()==12 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
So I used a combination of both post's code and hopefully changed the time it will trigger to noon and every time I override Box1_Port8(Hopefully this is the on my 2nd relay box) to always on with the smartphone app, it will not trigger the feeding modes automatically. Also it hopefully activate autofeeder 2 minutes after the ports I have set to turn off are off. Returning Box1_Port8 to auto will make the controller start feeding automatically again. I also deleted the part of the feeder being triggered by PWM.
Does this look correct?
How will I get this to trigger a relay to be ON during feeding mode?
Can I change how I turn off the auto feed mode to a virtual relay so I don't lose an outlet?
Many thanks for all your help.
Posted: Tue Jun 02, 2015 3:08 pm
the formatting on the code makes it hard to follow, but here's how it reads to me.
  • If Box1_Port8 is masked on AND you are not in FEEDING_MODE, you reset the feedStart flag to false
  • If you are in FEEDING_MODE AND feedStart flag is false, you flip feedStart flag to true and you grab the start of the feeding mode
  • You check if 120 seconds have elapsed and once they have elapse, you check if it is noon. If it is noon, then you start your FeedingMode, which triggers your autofeeder I presume.
Based on the code you just posted, your autofeeder ONLY starts if you manually put the controller in FEEDING_MODE.
The reason it reads this way is because of your IF statements. The problem with IF statements is that the next expression right after the condition will only be executed if the condition is true. You do not have anything right after the
line. So that means the next line is your if statement for starting the feeding mode. The "smarter" way to write the code is to always use the curly braces {} so there is no confusion as to what code is associated with the IF statements.
I just want to make sure I'm following your logic of what you want to do.
  • Trigger feeding mode every day at noon
  • IF you have Box1_Port8 masked on, DO NOT let feeding mode start
  • wait 2 minutes after feeding mode starts before you activate your auto feeder
I took some time and changed things around to make them simpler to follow (hopefully). Here's what I came up with (and it has not been tested, just written). You will also have to put in the code to start your autofeeder...I do not know how you do that.
// outside setup
boolean feedStart;
Timer feederDelayTimer;
// inside setup
feedStart = true;
// set the interval to 120 seconds (or 2 minutes)
feederDelayTimer.setInterval(120);
// inside loop
if (ReefAngel.Relay.isMaskOn(Box1_Port8)) {
	// disable auto feeding mode by masking ON the port
	feedStart = false;
} else {
	// reset the feedStart variable and allow feeding mode to start again once
	// the port is NOT masked on
	feedStart = true;
// Check if we are in the feeding mode
if ( ReefAngel.DisplayedMenu == FEEDING_MODE ) {
	// We are in feeding mode, let's see if our timer delay has expired
	if ( feederDelayTimer.isTriggered() ) {
		// delay timer is activated / expired, so we can activate the auto feeder
		// ACTIVATE AUTO FEEDER
// Start feed mode once per day at 12pm AND only if we are able to start feeding mode
// this means that feedStart is true and not turned off by the Box1_Port8 being turned on
if ((hour()==12 && minute()==0 && second()==0) && feedStart) {
	ReefAngel.FeedingModeStart();  // start feeding mode
	// Start the auto feeder delay timer
	feederDelayTimer.Start();
hopefully this is easy to follow. you will want to test it, but I think it should work ok for you.
Posted: Tue Jun 02, 2015 4:54 pm
by Rodasphoto
That is exactly what I would like to do. I also would like to be able to initiate the feeding mode by choosing the mode on my phone. I also do not know how to turn on a relay port to trigger my timer. Many thanks for fixing the code for me.
Posted: Tue Jun 02, 2015 7:22 pm
Rodasphoto wrote:That is exactly what I would like to do. I also would like to be able to initiate the feeding mode by choosing the mode on my phone. I also do not know how to turn on a relay port to trigger my timer. Many thanks for fixing the code for me.
You still can initiate the feeding mode from your phone BUT it will not trigger the 2 minute delay to turn on your autofeeder. That functionality will require a little more thought.
Ok. I had to go back and re-read your previous posts to make sure I follow you correctly. I had skipped over a few things because I wanted to focus on the main topic at hand. I also misread your part about removing the code to trigger your autofeeder when I did my breakdown of your original code. So part of my explanation of how I interpreted your code was off....my bad. The end result though with my revised code for you still holds true.
Now on to these questions:
If you want to turn on a port during feeding mode, you would just issue the command ReefAngel.Relay.On(Port8) (to turn on port 8).
I'm going to use an example building on my previous code. Let's say you wanted to turn on Port 7 on the main relay and Port 6 of your expansion relay when you enter feeding mode and have them both be off otherwise. This also assumes that they are not turned off when feeding mode is activated (by using the FeedingModePorts value in setup).
Here's what you would have:
		// Turn on these ports when the AutoFeeder is activated
		ReefAngel.Relay.On(Port1);
	// Turn on these ports when we are in feeding mode, no matter how it is triggered
	ReefAngel.Relay.On(Port7);
	ReefAngel.Relay.On(Box1_Port6);
} else {
	// Turn off these ports when we are not in Feeding Mode
	ReefAngel.Relay.Off(Port1);
	ReefAngel.Relay.Off(Port7);
	ReefAngel.Relay.Off(Box1_Port6);
Now, it gets a little more complicated if the ports get toggled ON/OFF in other parts of the code. That can be handled though. However, I started with a simple answer and we can always build on it or adapt it as needed.
Yes, you can do this rather easily. We just need to check the status of the relay and that will enable it. Again, I'm going to modify the code that I posted and show the change. I'm not going to repeat all the code from above, I'm just going to show what has changed.
// outside of setup, towards the top
// This is the first port of the second relay box, which is non-existant
#define VO_DISABLE_AUTO_FEEDER    Box2_Port1
// inside loop...the Box1_Port8 was changed to the virtual outlet
if (ReefAngel.Relay.isMaskOn(VO_DISABLE_AUTO_FEEDER)) {
   feedStart = false;
} else {
   feedStart = true;
Now, once you load this code on your controller, it will give you 2 expansion relay boxes. When you refresh the android app, it will show both of the expansion relay boxes. The first port on the second expansion box will allow you to disable the auto feeder. So I would change the name to be something like "Disable Auto Feeder". Then whenever you have it forced / masked on (where it shows the port ON and there is a green dot next to it), it will disable your autofeeder from activating at noon.
Here's the complete code with all these changes described above in it:
// outside setup
boolean feedStart;
// inside setup
feedStart = true;
// inside loop
   feedStart = false;
} else {
   feedStart = true;
} else {
I think that should answer your questions except for the one about using the Feeding Mode button on your phone to trigger everything that your autofeed mode at noon does. I'm still thinking on it.
Otherwise, let me know if you still have questions.
Posted: Fri Jul 17, 2015 12:43 pm
by jgwinner
Just wanted to post a quick note - love this fix! I'm using the same feeder, and this has enabled me to travel out of town for 3 weeks. Thank you!
Had to make a few changes to the code, however.
Timer is actually TimerClass now as near as I can tell. I cut that part out while debugging the code.
I'm also adding a 'pulse' timer, so that after say 2 minutes (the original delay), the pumps will turn on for just a couple of seconds. This spreads the food all through the tank. I have some very stupid fish that won't go up to the surface. You'd think they would after they are hungry, but the blue Tang really does have the personality of Dory. More importantly, I lost a diamond headed goby as he just hung around the sand - never got fed with the automatic feeder.
== John ==
Posted: Fri Jul 17, 2015 7:30 pm
jgwinner wrote:Just wanted to post a quick note - love this fix! I'm using the same feeder, and this has enabled me to travel out of town for 3 weeks. Thank you!
== John ==
awesome. glad it has helped you out. gotta keep those finicky fish happy. lol
Posted: Tue Oct 27, 2015 4:40 am
by Rodasphoto
== John ==
Nice. I lost a fish because the food not dispersing fast enough. Would you mind posting your code?
