Lights won't turn on
Posted: Mon Jun 01, 2015 12:19 am
by darkvenom
I have problem with my lighting . I have my light setup on port 1 to go on at 5pm turn off at 2am. On the controller port 1 is red does that mean there overheat problem? Also port 2 is red which is my heater. The tank is running at 76 so no over heat problem. How do i fix this problem is my temp probe bad? Here is code. Thanks is for the help .
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port1 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DosingPumpRepeat1( Port4 );
ReefAngel.DayLights( Port8 );
Re: Lights won't turn on
Posted: Mon Jun 01, 2015 5:23 am
by cosmith71
Red just means "off". Green is on.
Without seeing your memory file, it's hard to troubleshoot. Re-do your code with hard-coded values (in the wizard) and see if that works.
Posted: Mon Jun 01, 2015 2:54 pm
by darkvenom
The red led on the controller is on. What does that mean?
Posted: Mon Jun 01, 2015 2:56 pm
by darkvenom
Hmm what is hard coded values? How u go about doing that.. How do I pull up the memory info for u to look at?
Posted: Mon Jun 01, 2015 3:05 pm
It is either an ATO timeout or a overheat.
Generate another code with the wizard and choose hard coded settings instead of memory settings.
Posted: Wed Jun 03, 2015 6:58 pm
by darkvenom
ok thanks works great now !!
