Help with WiFiAlert
Posted: Mon Jun 01, 2015 10:49 am
by rrodriguess
Hi there
Does anyone know what I am doing wrong? It is supposed to send me a email alert using the portal, but it does nothing!
void emergencyShutDown(){
  static WiFiAlert t;
  t.SetDelay(0);
  t.Send("Emergency Shutdown");
  ReefAngel.PWM.SetDaylight(0); //turn off return pump
  ReefAngel.PWM.SetActinic(0); //turn off WP40
  ReefAngel.Relay.AllOff();
Seems simple.. but I tryed and tryed and nothing! :oops:
Rafa
Re: Help with WiFiAlert
Posted: Mon Jun 01, 2015 4:18 pm
how is that function being called from your code? it will not work unless it is called from the loop() section of your code.
so some scenario has to happen to trigger it, so you should post your entire code so we can see if it is called or how it gets called.
Posted: Mon Jun 01, 2015 6:52 pm
by rrodriguess
Yes.. it is called from the loop. In fact every once in a while I get a shutdown for some reason. So the rest of the code works.
I use similar code in others parts, with no luck either. I posted the shutdown function just to ilustrate.
In the loop() I have something like that:
if(ReefAngel.Params.PH>670) emergencyShutDown();
But I know... nothing better than the real code, so.. here it is. I am not a professional programmer, so dont be very judgmental..
#include <WiFiAlert.h>
void startTimeRunningRetPump();
void checkMaxSewer();
void checkMinWaterSump();
void checkMaxWaterSump();
void checkMaxReservoir();
void emergencyShutDown(char *message);
void WChange();
void DrawCustomMain();
void feedingMode();
void waterFallControl();
void setFlowPump();
void DrawRelays();
void DrawMainScreen();
void dailyRebootReefAngel();
void checkCleaningMode();
void phControl();
void tempControl();
void cleanningPump();
void lightsControl();
//######################################## CUSTOM MENU ###########################################
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu1_label[] PROGMEM = "Auto Feed";
prog_char menu3_label[] PROGMEM = "Water Level Calib.";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Shut Down";
prog_char menu6_label[] PROGMEM = "Cleaning Mode";
prog_char menu7_label[] PROGMEM = "Manual Lights on/off";
prog_char menu8_label[] PROGMEM = "Reboot ReefAngel";
  menu0_label, menu1_label, menu2_label,
  menu3_label, menu4_label, menu5_label,
  menu6_label, menu7_label, menu8_label//, menu8_label
//######################################## CUSTOM MODES ###########################################
//auto feed option on feed mode
boolean AUTOFEED=true;
//if true, disable max sump water level check to be able to clean the aquarium
//using the sump.
boolean CLEANING_MODE=false;
#define MAX_TIME_CLEANING_MODE  3600 //1 hour to clean aquarium. After that, regular checking is on.
//Water Change Status
int WC_STATUS=0;
//perform regular level checks after some time after return pump is on
boolean RETPUMP_ON_TIME=false;
//#################################### REEF ANGEL SCREEN LOG ######################################
//log message
boolean DISPLAYLOG=false;
char *LOGMESSAGE;
//#################################### RELAY PORTS ################################################
//Rename ports
#define LIGHTS            Port1
#define WOUT              Port2
#define COOLER_SUMP       Port3
#define CO2               Port4
#define WIN               Port5
#define WCHANGE           Port6
#define NOT_USED_01       Port7
#define DOSER_02          Port8
#define HEATER_SUMP       Box1_Port1
#define FEEDER            Box1_Port2
#define DOSER_01          Box1_Port3
#define UV                Box1_Port4
#define HEATER_RESERVOIR  Box1_Port5
#define COOLER_RESERVOIR  Box1_Port6
#define O2                Box1_Port7
#define CLEANER_PUMP      Box1_Port8
//#################################### CUSTON VARS ################################################
#define RETPUMP_ON_TIME_C_VAR    0
#define LAST_AWC                 1
#define EMERNCY_SHUTDOWN         2
#define LAST_AUTO_FEED           3
//#################################### TEMP PROBES ################################################
//Define Temp Probes
#define SUMP_TEMP_PROBE        T1_PROBE
#define RESERVOIR_TEMP_PROBE   T2_PROBE
#define REFUGIUM_TEMP_PROBE    T3_PROBE
//#################################### WATER LEVEL ################################################
//Define WaterLevel Channels
#define WL_SEWER          1
#define WL_REFUGIUM       2
#define WL_RESERVOIR      3
#define WL_SUMP           4
//######################## WATER CHANGE PARAMETERS AND WATER LEVEL CONTROL ########################
//Define times (hour) to Auto Water Change (AWC)
#define WCHANGE_T1      9
#define WCHANGE_T2      16
#define WCHANGE_T3      22
//Min e Max parameters to Auto Water Change (AWC)
#define MIN_SEWER                    10    //max sewer level to be able to begin AWC
#define MAX_SEWER                    30   //sump max level before emergency sistem shutdow
#define MIN_RESERVOIR_START_WC       80   //min reservoir to be able to begin AWC
#define MAX_RESERVOIR                84   //max reservoir to fill after AWC
#define MIN_RESERVOIR_DURING_CHANGE  15   //min reservoir at change, to avoid pump demage
#define MAX_SUMP                     60   //ideal sump level after AWC
#define MIN_WATER_SUMP		     40   //minimun Sump Level, preventing pump damage
#define PROXY_MAX_SUMP		     1.20 //Value to avoid emercy shotdown on every tyne little level variation.
#define PROXY_MAX_RESERVOIR	     1.06 //Value to avoid emercy shotdown on every tyne little level variation.
//AWC max time
#define AWC_MAX_TIME_COMPLETE_CHANGE    1200;  //20 minutes
#define AWC_MAX_TIME_RESERVOIR_FILL     300; //5 minutes
//AWC Max Temp Dif
#define AWC_MAX_TEMP_DIF      10 //or 1 C
#define RETURN_PUMP_SECONDS_ON	180 //Running pump time, in seconds, before checking min sump level
#define TIME_TO_EMERGENCY_SHUTDOWN  10 //time to shutdown system. Used to avoid water level miss-reading.
#define WCHANGE_DOSER_SECOND 6 //awc dosing time
//######################################## LIGHTS  ################################################
//Time On/Off Lights
#define LIGHTS_ON_H      19
#define LIGHTS_OFF_H     23
//######################################## FEEDING  ################################################
//Time do auto-feed
#define FEEDING_H_T1     19
#define FEEDING_M_T1     30
#define FEEDING_H_T2     20
#define FEEDING_M_T2     30
//Number of feeding times done in 15 minutes
#define FEEDING_TIMES		5
#define SECONDS_FEEDER_ON       10 //seconds feeder to complete 1 full rotation
//######################################## REBOOTING  #############################################
//Time to reboot reefangel
#define REBOOT_HOUR      0
#define REBOOT_MINUTE    0
//######################################## PH CONTROL  #############################################
//Define Max and Min PH
#define TARGET_PH               635
#define PH_SUPERIOR_BOUND       639
#define PH_INFERIOR_BOUND       630
#define MAX_PH_TO_ALERT         645
#define MIN_PH_TO_ALERT         625
#define TIME_TO_PH_CHECK        1200 //20 minutes to check low ph and to add bicarbonate
#define DOSER_INCREASE_TIME     10
//###################################### TEMP CONTROL  #############################################
//Target tenperature, in celcius
#define TARGET_TEMP             285
#define MIN_TEMP                280
#define MAX_TEMP                290
#define MAX_TEMP_TO_ALERT       300
#define MIN_TEMP_TO_ALERT       270
//###################################### WP40 CONTROL #############################################
#define WP40_FLOW_RATE  30
#define WP40_VARIATION  5
//################################### WATER FLOW CONTROL ##########################################
//Consts to regulate the water flow
#define INI_FLOW                     100
#define SWITCH_ON_SECONDS            3
#define STEP_DOWN_VALUE              10
#define SWITCH_DOWN_SECONDS          2
#define TOTAL_STEP_DOWN_VALUE        1
#define RESET_TIME_SECONDS           3600
#define CLENER_PUMP_CICLE_MINUTES    1
#define CLENER_PUMP_DURATION_SECONDS 15
#define SWITCH_ON_CLEANER_SECONDS    5
//################################### CLEANNING PUMP CONTROL ######################################
#define CLEANNING_PUMP_ON_TIME   60  //1 minute on
#define CLEANNING_PUMP_OFF_TIME  600 //10 minutes off
  ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); //inicialize Menu
  ReefAngel.SetTemperatureUnit(Celsius);  // set to Celsius Temperature
  ReefAngel.AddMultiChannelWaterLevelExpansion();  // Water Level Expansion Module
  ReefAngel.FeedingModePorts = 0; //control it manually
  ReefAngel.WaterChangePorts = 0;  //control it manually
  ReefAngel.OverheatShutoffPorts = 0;  //control it manually
  ReefAngel.LightsOnPorts = 0;  //control it manually
  //relays allways on
  ReefAngel.Relay.On(UV);
  //dns
  ReefAngel.DDNS("home");
  //relays allways off
  ReefAngel.Relay.Off(LIGHTS);
  ReefAngel.Relay.Off(WOUT);
  ReefAngel.Relay.Off(COOLER_SUMP);
  ReefAngel.Relay.Off(CO2);
  ReefAngel.Relay.Off(WIN);
  ReefAngel.Relay.Off(WCHANGE);
  ReefAngel.Relay.Off(NOT_USED_01);
  ReefAngel.Relay.Off(DOSER_02);
  ReefAngel.Relay.Off(HEATER_SUMP);
  ReefAngel.Relay.Off(FEEDER);
  ReefAngel.Relay.Off(DOSER_01);
  ReefAngel.Relay.Off(HEATER_RESERVOIR);
  ReefAngel.Relay.Off(COOLER_RESERVOIR);
  ReefAngel.Relay.Off(O2);
  ReefAngel.Relay.Off(CLEANER_PUMP);
  //ReefAngel Portal
  ReefAngel.Portal("rrodriguess","xxxxxxxxxxxxxxx";
  //Lights Control
  lightsControl();
//#################### MAIN PUMPS ####################
  //Set runnning return pump time
  //Set flow pump WP40
  setFlowPump();
  //control water fall to sump
  waterFallControl();
  //CleanningPump
  cleanningPump();
//#################### WATER CHANGE ####################
  //Auto Water Change (AWC) function
  WChange();
//#################### MODES  ####################
  //feeding mode
    feedingMode();
  //Cleaning Mode contro
//#################### CONTROLS ####################
  //Ph control using CO2 (solenoid) and dosing 02
  phControl();
  //Sump and Reservoir Temp Control using heaters and fan
  tempControl();
//#################### CHECKS  ####################
  //prevent pump damage on low eater level
  //prevent sump overflow
  //prevent sewer overflow
  checkMaxSewer();
  //prevent Reservoir overflow
  //#################### REBOOT ####################
  //reboot Reefangel midnigh to prevent address variable corrution
void lightsControl(){
  if(hour()>=LIGHTS_ON_H && hour() <= LIGHTS_OFF_H) ReefAngel.Relay.Set(LIGHTS, true);
  else ReefAngel.Relay.Set(LIGHTS, false);
void tempControl(){
  //temp control - heater
  if(ReefAngel.Params.Temp[SUMP_TEMP_PROBE] >= TARGET_TEMP) ReefAngel.Relay.Set(HEATER_SUMP, false);
  if(ReefAngel.Params.Temp[SUMP_TEMP_PROBE] <= MIN_TEMP) ReefAngel.Relay.Set(HEATER_SUMP, true && RETPUMP_ON_TIME);
  if(ReefAngel.Params.Temp[RESERVOIR_TEMP_PROBE] >= TARGET_TEMP) ReefAngel.Relay.Set(HEATER_RESERVOIR, false);
  if(ReefAngel.Params.Temp[RESERVOIR_TEMP_PROBE] <= MIN_TEMP) ReefAngel.Relay.Set(HEATER_RESERVOIR, true);
  //temp control - fan
  if(ReefAngel.Params.Temp[SUMP_TEMP_PROBE] <= TARGET_TEMP) ReefAngel.Relay.Set(COOLER_SUMP, false);
  if(ReefAngel.Params.Temp[SUMP_TEMP_PROBE] >= MAX_TEMP) ReefAngel.Relay.Set(COOLER_SUMP, true  && RETPUMP_ON_TIME);
  if(ReefAngel.Params.Temp[RESERVOIR_TEMP_PROBE] <= TARGET_TEMP) ReefAngel.Relay.Set(COOLER_RESERVOIR, false);
  if(ReefAngel.Params.Temp[RESERVOIR_TEMP_PROBE] >= MAX_TEMP) ReefAngel.Relay.Set(COOLER_RESERVOIR, true);
void phControl(){
  static boolean doseIt=false;
  static long timeToCheck=now()+TIME_TO_PH_CHECK;
  static long runningTime=0;
  static boolean check=true;
  if(RETPUMP_ON_TIME==false || CLEANING_MODE || WC_STATUS>0 || ReefAngel.DisplayedMenu==FEEDING_MODE){
    ReefAngel.Relay.Set(CO2, false);
    ReefAngel.Relay.Set(O2, false);
    ReefAngel.Relay.Set(DOSER_02, false);
    return;
  if(doseIt==false && ReefAngel.Params.PH < PH_INFERIOR_BOUND) doseIt = true;//set dose if PH < PH INFERIOR BOUND
  if(doseIt==true && ReefAngel.Params.PH >= TARGET_PH) doseIt = false; //set back dose only if PH >= TARGET_PH
  if(now()>timeToCheck){ //set next time to check;
    check=true;
  if(doseIt && check){
    runningTime = now() + DOSER_INCREASE_TIME;
    check=false;
  ReefAngel.Relay.Set(DOSER_02, runningTime >= now() && doseIt);
  //PH Control - increase PH
  ReefAngel.PHControl(O2,PH_INFERIOR_BOUND,TARGET_PH);
  //PH Control - decrease PH
  if(ReefAngel.Relay.Status(UV) && RETPUMP_ON_TIME){
    ReefAngel.CO2Control(CO2,TARGET_PH,PH_SUPERIOR_BOUND );
  else {
void checkCleaningMode(){
  static long startTime=0;
  if(WC_STATUS>0 || ReefAngel.DisplayedMenu==FEEDING_MODE) CLEANING_MODE=false;
  if(CLEANING_MODE){
    if(startTime==0){
      startTime=now();
    if((now()-startTime) > MAX_TIME_CLEANING_MODE){
      CLEANING_MODE = false;
  else{
    startTime=0;
void setFlowPump(){
  //set wp40 flow
  if(ReefAngel.Relay.Status(LIGHTS) && ReefAngel.DisplayedMenu!=FEEDING_MODE && RETPUMP_ON_TIME && CLEANING_MODE==false){
    ReefAngel.PWM.SetActinic( ReefCrestMode(WP40_FLOW_RATE,WP40_VARIATION,false) );
  else {
void cleanningPump(){
  if(RETPUMP_ON_TIME){
    ReefAngel.DosingPumpRepeat( CLEANER_PUMP,0,10,120);   //run every 10 minutes for 120 seconds
  else {
    ReefAngel.Relay.Set(CLEANER_PUMP,false);
void dailyRebootReefAngel(){
  //reboot reefangel only if its not feeding time and not AWC
  if(hour()==REBOOT_HOUR && minute()==REBOOT_MINUTE && second()==0 && ReefAngel.DisplayedMenu!=FEEDING_MODE && WC_STATUS==0) while(true);
void waterFallControl(){
  static long countSeconds=0;
  static boolean lastStatus = ReefAngel.HighATO.IsActive();
  static long startTime=now();
  static long OperatingPWM=INI_FLOW;
  static long maxPWM=INI_FLOW;
  static long upCount=SWITCH_ON_SECONDS;
  static boolean stepDown=false;
  if(ReefAngel.DisplayedMenu==FEEDING_MODE  || CLEANING_MODE==true){
    return;
  ReefAngel.PWM.SetDaylight(OperatingPWM);
  if(ReefAngel.HighATO.IsActive() != lastStatus){ //last status changed
    lastStatus=ReefAngel.HighATO.IsActive();
    startTime=now();
  countSeconds = now()-startTime;
  //emergency shutdown
  if(lastStatus==true && countSeconds >=70) emergencyShutDown("ATO On 70");
  //step down STEP_DOWN_VALUE every SWITCH_ON_SECONDS
  if(lastStatus==true && countSeconds > upCount){
    OperatingPWM = OperatingPWM - STEP_DOWN_VALUE;
    upCount = upCount + SWITCH_ON_SECONDS;
    stepDown=true;
  //step up to maxPWM; Regulate maxPWM - TOTAL_STEP_DOWN_VALUE every stepdown sequence
  if(lastStatus==false && countSeconds > SWITCH_DOWN_SECONDS) {
    if(stepDown){
      stepDown=false;
      maxPWM=maxPWM-TOTAL_STEP_DOWN_VALUE;
    OperatingPWM = maxPWM;
  //reset maxPWN with INI_FLOW every RESET_TIME_SECONDS
  if(lastStatus==false && countSeconds >= RESET_TIME_SECONDS){
    startTime=now();
    maxPWM = INI_FLOW;
void startTimeRunningRetPump(){
  //set global var true after return pump is running for a certain period of time.
  static boolean timerOn=false;
  static long finalTime=0;
  if(ReefAngel.PWM.GetDaylightValue() >= 30 && !timerOn) {
    finalTime = now()+RETURN_PUMP_SECONDS_ON;
    timerOn=true;
  if(now()>=finalTime && ReefAngel.PWM.GetDaylightValue() >= 30) {
    RETPUMP_ON_TIME=true;
    ReefAngel.CustomVar[EMERNCY_SHUTDOWN]=false; //system is online
  if(ReefAngel.PWM.GetDaylightValue() < 30){
    timerOn=false;
  ReefAngel.CustomVar[RETPUMP_ON_TIME_C_VAR]=RETPUMP_ON_TIME;
  if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR) > (MAX_RESERVOIR*PROXY_MAX_RESERVOIR)){
    if(startTime==0){
      startTime=now();
    if(now()-startTime > TIME_TO_EMERGENCY_SHUTDOWN){
      emergencyShutDown("Res > Max");
  else {
    startTime =0;
  if(ReefAngel.WaterLevel.GetLevel(WL_SEWER) > MAX_SEWER){
    if(startTime==0){
      startTime=now();
      emergencyShutDown("Sewer > Max");
  else {
    startTime =0;
  if(ReefAngel.WaterLevel.GetLevel(WL_SUMP) <=MIN_WATER_SUMP){
    if(startTime==0){
      startTime=now();
      emergencyShutDown("Sump < Min");
  else {
    startTime =0;
  static boolean isOn=false;
  if(RETPUMP_ON_TIME && WC_STATUS==0 && ReefAngel.DisplayedMenu!=FEEDING_MODE && !CLEANING_MODE){
    if(isOn){
      ReefAngel.Relay.Set(WOUT, ReefAngel.WaterLevel.GetLevel(WL_SUMP) > MAX_SUMP);
      isOn = ReefAngel.WaterLevel.GetLevel(WL_SUMP) > MAX_SUMP;
    else {
      if(ReefAngel.WaterLevel.GetLevel(WL_SUMP) > MAX_SUMP*PROXY_MAX_SUMP){
        if(startTime==0){
          startTime=now();
      else {
        startTime=0;
      if(ReefAngel.WaterLevel.GetLevel(WL_SUMP) > MAX_SUMP*PROXY_MAX_SUMP && now()-startTime > TIME_TO_EMERGENCY_SHUTDOWN){
        isOn = true;
        startTime=0;
  else {
    startTime=0;
void emergencyShutDown(char *message){
  static WiFiAlert t;
  t.SetDelay(0);
  t.Send(message);
  WC_STATUS=0; //cancel any AWC
  DISPLAYLOG=true;
  LOGMESSAGE = message;
  ReefAngel.CustomVar[EMERNCY_SHUTDOWN]=true;
void WChange()
  static boolean forceIt=false;
  static boolean extraRun=false;
  static long wcDosingTimer=0;
  static WiFiAlert t;
  t.SetDelay(0);
  if(WC_STATUS==0  && RETPUMP_ON_TIME && (ReefAngel.DisplayedMenu==WATERCHANGE_MODE || ((hour()==WCHANGE_T1 || hour()==WCHANGE_T2 || hour()==WCHANGE_T3) && minute()==0))){
    WC_STATUS=1;
    if((hour()==WCHANGE_T1 || hour()==WCHANGE_T2 || hour()==WCHANGE_T3) && minute()==0) forceIt=false;
    else forceIt=true;
    if(WC_STATUS==0  && RETPUMP_ON_TIME==false && ReefAngel.DisplayedMenu==WATERCHANGE_MODE){
  if(WC_STATUS==0) return;
  if(timerOn && now() > finalTime){
    WC_STATUS = 8;
    emergencyShutDown("AWC Time Exc");
  switch (WC_STATUS){
  case 1:
    ReefAngel.DisplayedMenu = WATERCHANGE_MODE;
    if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MIN_RESERVOIR_START_WC){
      t.Send("Filling reservoir.");
      WC_STATUS=5;
      timerOn=true;
      extraRun=forceIt; //set extraRun only if forceIt=true; Otherwise just fill the reservoir.
      if(extraRun){
        finalTime = now() + AWC_MAX_TIME_COMPLETE_CHANGE + AWC_MAX_TIME_RESERVOIR_FILL;
      else {
        finalTime = now() + AWC_MAX_TIME_RESERVOIR_FILL;
      return;
    else {
      t.Send("AWC Started");
      timerOn=true;
      finalTime = now()+AWC_MAX_TIME_COMPLETE_CHANGE;
      if(forceIt) WC_STATUS=3;
      else WC_STATUS=2;
      return;
    break;
  case 2:
    //check min sewer
    if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)>MIN_SEWER){
      emergencyShutDown("AWC Canceled: Sewer > Min Sewer");
      WC_STATUS = 8;
      return;
    //check temperature difference
    if(abs(ReefAngel.Params.Temp[RESERVOIR_TEMP_PROBE] - ReefAngel.Params.Temp[SUMP_TEMP_PROBE]) > AWC_MAX_TEMP_DIF){
      t.Send("AWC not realized due to Temperature difference");
      WC_STATUS = 8;
      return;
    //check return pump minimun running time
    if(!RETPUMP_ON_TIME){
      t.Send("AWC Canceled: Return Pump Not Running min time");
      WC_STATUS = 8;
      return;
    WC_STATUS=3;
    break;
  case 3:
    //AWC: reservoir to sump
    if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)>(MIN_RESERVOIR_DURING_CHANGE)){
      ReefAngel.Relay.On(WCHANGE);
    else{
      WC_STATUS = 4;
    break;
  case 4:
    //AWC: sump to sewer
    if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)>(MAX_SUMP)){
      ReefAngel.Relay.On(WOUT);
    else{
      WC_STATUS = 5;
    break;
  case 5:
    //get doser ready
    wcDosingTimer= now() + WCHANGE_DOSER_SECOND;
    WC_STATUS = 6;
    break;
  case 6:
    //dosing
    if (now()<wcDosingTimer) {
      ReefAngel.Relay.On(DOSER_01);
    else {
      wcDosingTimer=0;
      WC_STATUS = 7;
    break;
  case 7:
    //fill reservoir for the next water change
    if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MAX_RESERVOIR){
      ReefAngel.Relay.On(WIN);
    else{
      t.Send("AWC Ended");
      ReefAngel.CustomVar[LAST_AWC]=hour();
      WC_STATUS = 8;
    break;
  case 8:
    timerOn=false;
    finalTime=0;
    WC_STATUS=0;
    if(extraRun){
      extraRun=false;
      WC_STATUS=3;
    else{
      forceIt=false;
    break;
  } //switch
void feedingMode(){
  static long feeding=0;
  static int nrFeedings=0;
  static long timeToRun=0;
  static long timeOffFeeder=0;
  static WiFiAlert t;
  t.SetDelay(0);
  if(WC_STATUS==0 && CLEANING_MODE==false && (ReefAngel.DisplayedMenu==FEEDING_MODE || ((hour()==FEEDING_H_T1  && minute()==FEEDING_M_T1) || (hour()==FEEDING_H_T2 && minute()==FEEDING_M_T2)))){
    if(ReefAngel.DisplayedMenu!=FEEDING_MODE) ReefAngel.FeedingModeStart();
    t.Send("Feed Mode Started");
    if(AUTOFEED){
      timeToRun = 900/(FEEDING_TIMES+1);
      if(feeding==0){
        feeding = now()+timeToRun;
      if(feeding > 0 && now()>=feeding && nrFeedings < FEEDING_TIMES){
        timeOffFeeder = now() + SECONDS_FEEDER_ON;
        nrFeedings++;
        ReefAngel.CustomVar[LAST_AUTO_FEED]=hour();
        feeding = 0;
      ReefAngel.Relay.Set(FEEDER, timeOffFeeder  >= now());
  else {
    AUTOFEED=true;
    feeding=0;
    nrFeedings=0;
    timeToRun=0;
  static byte screenCount=0;
  static boolean screenHome=true;
  if(ReefAngel.Joystick.IsLeft() || ReefAngel.Joystick.IsRight()){
    screenHome=!screenHome;
  if(screenHome)  DrawMainScreen();
  if(!screenHome) DrawRelays();
void DrawMainScreen(){
  char text[80];
  char str[80];
  //Initial Title
  if(DISPLAYLOG){
    ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 40, 4, "          ");
    ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 4 , LOGMESSAGE);
  else {
    ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 40, 4 , "RafaLu");
  //Division Line
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
  //Main Temperature
  ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 6, 15, "SumpTemp:");
  ConvertNumToString(text, ReefAngel.Params.Temp[SUMP_TEMP_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 63, 15, text);
  //PH
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 25, "SumpPH:");
  ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 63, 25, text);
  //Res Temperature
  ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 6, 35, "ResTemp:");
  ConvertNumToString(text, ReefAngel.Params.Temp[RESERVOIR_TEMP_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 63, 35, text);
  //Ref Temperature
  ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 6, 45, "RefTemp:");
  ConvertNumToString(text, ReefAngel.Params.Temp[REFUGIUM_TEMP_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 63, 45, text);
  //Division Line
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 55, 132, 55);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 57, "FlowSwitch:");
  strcpy(text,"Off");
  if(ReefAngel.HighATO.IsActive()){
    strcpy(text,"On");
  ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 72, 57, "     ");
  ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 72, 57, text);
  //Return Pump
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 67, "                    ");
  ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(), 1);
  strcpy (str,"Return Pump At: ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 67, str);
  //Division Line
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 77, 132, 77);
  //WATER LEVEL 01
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 89, "          ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SEWER), 1);
  strcpy (str,"SEWER:");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 89, str);
  //WATER LEVEL 02
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 89,"          ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_REFUGIUM), 1);
  strcpy (str,"REF: ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 89,str);
  //WATER LEVEL 03
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 101, "          ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR), 1);
  strcpy (str,"RES:  ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 101, str);
  //WATER LEVEL 04
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 101,"         ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SUMP), 1);
  strcpy (str,"SUMP:");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 101,str);
  //Date and Time
  ReefAngel.LCD.DrawDate(6,120);
void DrawRelays(){
  //Initial Title
  if(DISPLAYLOG){
  else {
  //Division Line
  //Relays
  //B01 R01
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,20,"Lights");
  //B01 R02
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,20,"WOut");
  //B01 R03
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,30,"Sump Fan");
  //B01 R04
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,30,"CO2");
  //B01 R05
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,40,"WIn");
  //B01 R06
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,40,"WChange");
  //B01 R07
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,50,"Not Used");
  //B01 R08
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,50,"Not Used");
  //B02 R01
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,70,"Sump Heat");
  //B02 R02
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,70,"Feeder");
  //B02 R03
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,80,"Doser 01");
  //B02 R04
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,80,"UV");
  //B02 R05
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,90,"Res Heat");
  //B02 R06
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,90,"Res Fan");
  //B02 R07
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,100,"O2");
  //B02 R08
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,6,100,"Clnr Pump");
  ReefAngel.LCD.DrawCircleOutletBox(60, 23, TempRelay, true);
  byte TempRelay2 = ReefAngel.Relay.RelayDataE[0];
  ReefAngel.LCD.DrawCircleOutletBox(60, 73, TempRelay2, true);
void MenuEntry1()
  AUTOFEED=false;
void MenuEntry2()
  AUTOFEED=true;
void MenuEntry3()
void MenuEntry4()
  ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry5()
  ReefAngel.SetupCalibratePH();
void MenuEntry6()
  // Clear the screen
  // Display some text on the screen
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 5, 10, "Turn Everything Off");
  // Turn off the ports
  emergencyShutDown("Manual ShutDown");
  ReefAngel.Relay.Write();
void MenuEntry7()
  CLEANING_MODE = !CLEANING_MODE;
void MenuEntry8()
  if(ReefAngel.Relay.Status(LIGHTS)==false){
    ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
      ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif  // RelayExp
  else {
    ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
      ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif  // RelayExp
void MenuEntry9()
  while(true);
Posted: Tue Jun 02, 2015 5:37 pm
I'm reading through your code and it is quite detailed. I have noticed a couple small little critiques but nothing significant so far.
I will ask this, does everything in your code function properly except for the emergencyShutDown() function?
I'm looking through it more closely now and will most likely have a couple suggestions to make to help isolate the scenarios better.
Posted: Tue Jun 02, 2015 8:22 pm
by rrodriguess
Tks binder
You are very polite calling it "detailed" instead of messy... haha
I looked Lee PDE and I got a question. Can we send space? Or do we have to substitute space by "+"?
Any suggestion at the code, feel free to send here or by pm.
Rafa
Posted: Tue Jun 02, 2015 8:47 pm
I do not believe you can send space or special characters. Unless someone adds an automatic encoding function which I could not find anything simple to do that with.
Posted: Wed Jun 03, 2015 4:24 am
by rrodriguess
Inevo
Once changed the code by removing special characters, WiFiAlert worked as a charm.
About some code to URL encode strings, here is something that might be usefull:
http://forum.arduino.cc/index.php?topic=99538.0
Despite some changes in code during the post it seems to work after all..
Rafa
Posted: Wed Jun 03, 2015 7:31 am
yeah, i was noticing the code regarding spaces. my tests were not working properly and it was from the spaces.
Sent from my Nexus 7
Posted: Sun Jun 07, 2015 7:36 am
rrodriguess wrote:Inevo
Rafa
Yeah that's a bit of work that I didn't want to get involved with testing. Switching space to + was much easier. If someone wants to try hacking the URL encoding in, I'd be happy to test it.
