Help with shutting off LEDs at 15%
Posted: Sun Jan 01, 2012 5:33 pm
by jallan258
I need some help with my code. As I understand it, the Mean well drivers flicker under 15% so I wanted to have my leds shut off when it reached 15%. Here is my current code.
// Autogenerated file by RAGen (v1.1.0.126), (01/01/2012 17:05)
// RA_010112_1705.pde
#define DisplayImages
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.Wavemaker1(Port4);
    ReefAngel.Wavemaker2(Port5);
    ReefAngel.StandardFan(Port6);
 ReefAngel.PWM.SetActinic(PWMSlope(10,30,19,30,15,80,60,ReefAngel.PWM.GetActinicValue()));
 ReefAngel.PWM.SetDaylight(PWMSlope(11,30,18,30,15,80,60,ReefAngel.PWM.GetDaylightValue()));
As you could see I have the PWMSlope function working properly but I can't get it to completely shut off when it reaches 15%. Can someone help me code this? Thank You
Re: Help with shutting off LEDs at 15%
Posted: Sun Jan 01, 2012 5:54 pm
You can start and end the slope with 17% for example and time it to turn the relay off at the end of the slope.
