What fits on a RA Standard?
Posted: Fri Jun 12, 2015 7:19 pm
So I have two RAs. The one I use for my main tank and the back up one that I bought originally. I am trying to setup the basic RA (RA Standard) to run a temporary nanocube. The problem I am finding is that NOTHING fits! I have downgraded to 1.0.9 libraries and 1.0.7 libraries... still too large. I am just trying to load the preloaded code. I need to run basic functions plus PWM. Any advice?
Preloaded code:
Preloaded code:
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 5, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
ReefAngel.Relay.On(Port8); // Always on
ReefAngel.StandardATO(Port1); // Standard ATO
ReefAngel.MoonLights(Port2); // Moonlights or Refugium
ReefAngel.StandardLights(Port3,30); // Actinic Lights
ReefAngel.StandardLights(Port4,0); // Daylight Lights
ReefAngel.Wavemaker1(Port5); // Wavemaker 1
ReefAngel.Wavemaker2(Port6); // Wavemaker 2
ReefAngel.StandardHeater(Port7); // Heater
ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
ReefAngel.ShowInterface(); // Display everything on the LCD screen
