Help with 2 X Jebao Wave-makers and Application Iterface
Posted: Thu Jun 18, 2015 10:08 am
So I've been jacking with my Jebao's since I got my speed-cables in the mail last Saturday. My Jebao's are on port 5 and port 6. When using the RA Wizard for setup only port 5 seems to be operational clicking on every several minutes, I have yet to see port 6 active. I tried a custom code after reading various member posts but neither wave-maker turned on at all even though the head-unit and app said otherwise.
I have 2 X Jebao RW-8's connected by 2 speed-cables to Daylight and Actinic channel dimming ports.
This is what I was attempting to do:
1. Set custom port labels
2. Set a day wave pattern to reef crest min @30% and max @60%
one set to sync and the other to anti-sync on @14:00 and off @20:30
Set night to lagoon @30%
one set to sync and the other to anti-sync on @20:31 and off @13:59
3. Setup app control for wave-makers
I would like to change settings "intensity, mode, timer" for my wave-makers from the app or at least through the head-unit.
I will post my code hopefully someone can spot what I did wrong...
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
//Define labels for 2014 LCD screen
#define ATO 8
#define Reactor 7
#define WM2 6
#define WM1 5
#define UVL 4
#define Heater 3
#define Skimmer 2
#define Return 1
ReefAngel.StandardHeater( Port3,751,791 );
ReefAngel.WavemakerRandom( Port5,30,60 );
ReefAngel.WavemakerRandom( Port6,30,60 );
ReefAngel.StandardATO( Port8,60 );
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,20,30,30,60,15,30) );
ReefAngel.PWM.SetActinic( PWMSlope(14,0,21,0,30,60,15,30) );
ReefAngel.DCPump.SetMode( ReefCrest,60,10 );
ReefAngel.PWM.SetDaylight( PWMSlope(20,31,13,59,30) );
ReefAngel.PWM.SetActinic( PWMSlope(20,31,13,59,30) );
ReefAngel.DCPump.SetMode( Lagoon,30,10 );
ReefAngel.Portal( "raythesaint" );
