PH Calibration
Posted: Sat Jul 18, 2015 7:45 pm
by Civics14
I don't think my PH calibration is going correctly
Ran the calibration test, results are:
7.0 - 511 (7.0 solution reads 7.0 after calibration)
10.0 - 748 (10.0 solution reads 9.5 after calibration)
Any help with those numbers?
Re: PH Calibration
Posted: Sun Jul 19, 2015 6:29 am
by cosmith71
You might need to leave the probe in the calibration solution for several minutes to get to the final calibration number when you're calibrating.
Re: PH Calibration
Posted: Sun Jul 19, 2015 1:25 pm
by Civics14
Hi Colin, I left it in there for almost 10 min each to a point where the numbers stayed put and stopped changing
Re: PH Calibration
Posted: Sun Jul 19, 2015 8:20 pm
by fishflipper
are you using an expansion module?
Re: PH Calibration
Posted: Mon Jul 20, 2015 4:15 am
by Civics14
No expansion module here. I was hoping to get Roberto's help because he helped me with this before where my PH reading was off like this.
Re: PH Calibration
Posted: Mon Jul 20, 2015 4:41 am
by cosmith71
I'm sure Roberto will chime in.
Silly question, but when you're calibrating, you're moving over to OK before you hit the button, correct? It starts off on "Cancel".
Re: PH Calibration
Posted: Mon Jul 20, 2015 5:24 am
by Civics14
LOL. Yes. Thank you Collin. Actually I go into the code and add in a few lines that Roberto had me do the last time.
Re: PH Calibration
Posted: Mon Jul 20, 2015 8:11 am
The numbers look fine.
You can hard code them.
ReefAngel.PHMin=511;
ReefAngel.PHMax=760;
Play with the 760 until it turns pH 10. Or go into calibration mode with the probe in the ph 10 fluid and write down the number you see it.
Re: PH Calibration
Posted: Mon Jul 20, 2015 8:47 am
by Civics14
Thanks Roberto, I'll try those numbers. No idea what they mean, but the last time you adjusted it for me, it worked.
rimai wrote:The numbers look fine.
