New Reef Angel Owner!
Posted: Wed Jan 04, 2012 8:09 pm
by Zechenia
Hey!
I just purchased a Reef Angel (bought it used) and will be purchasing the wifi attachment here in a couple weeks. The controlled hasn't arrived yet, and I am eager to start coding! I want to start using RA Gen, then modify the sections I need different. This post is more of a place to list my ideas, and also to ask a couple questions. Definitely not looking for help coding (besides, isn't that half the fun?!)
So, here are my plans. I'm assuming (hoping) these are all possible, but haven't had a chance to look into the libraries and code base much to see how much work it would be What do you think of them?
1. Float Switches:
A. I already have an ATO, so I want to just plug that in. However, I want to use the float switches as alerts. I'm planning (once I figure out a good way to mount it) on mounting it above my current ATO location, and if it ever floats, I want it to alarm me, and turn off the outlet for the ATO.
B. I have a HOB refugium, so I want a similar set up with the other Float, turning off the pump it ever floats
2. Waterchange: I want to have the water change mode turn off the ATO, Powerheads, Skimmer, and Refugium pump. I then want it to prompt for a joystick input. On the joystick press, I want it to start the ATO. I fill via-ATO so I get the exact level.
3. Heater: My Heater is in my HOB refugium. I plan on only allowing the heater to be on if the refugium pump is on.
4. WaveMaker: Standard
5. Alerts: I want to keep a log of standard alerts (I believe the client does this automatically?) but I also want to set up email or text alerts for reminders (things like weekly emails for waterchanges/testing). Is this doable?
6. Lights: My lights have a built in timer. I want to have them always on (and let the built in timer controll it). The only time they will lose power is in extreme overheating
Questions:
I want three settings on my Wavemaker: Pump A on, Pump B on, and Both Pump A and Pump B on. With the wavemaker functions, does it already do this? or is it set up for only one or the other?
I read somewhere that PH probs need to be calibrated very frequently. Is this really the case? I wanted to set up a PH monitoring function that turns on all the pumps and powerheads if the PH drops too far. Don't know if that's ideal though if I need to constantly be calibrating it.
This turned out longer than I anticipated. Sorry!
Re: New Reef Angel Owner!
Posted: Wed Jan 04, 2012 8:57 pm
All of that is possible :)
The standard function for wavemaker will always alternate them. Some other logic will need to be code for the way you want them to work.
Recalibration is a very personal option. I know people that calibrate every week and others that never calibrate. I'm in the latter group. I can't remember the last time I calibrated my probe :roll:
You will need to once in a while drop it in vinegar to remove any algae or bacteria growth that can occur. I do that like every year or so. But that's just me.
Posted: Thu Jan 05, 2012 8:43 am
by Zechenia
ok, Perfect! I'll let ya know how it goes one I get started :D
Posted: Sun Jan 08, 2012 2:30 pm
by Zechenia
Ok, I have my first two questions as I am coding!
What do I need to add in my PDE file to be able to use the float switches inside my the loop function? Also, how do I know which float valve is which when I install them?
Posted: Sun Jan 08, 2012 3:32 pm
If you use RAGen, you don't need to add anything.
Posted: Mon Jan 09, 2012 8:47 am
by Zechenia
I used RAGen to set up the file, but am hand coding a lot. I am going to be using the float switches as overflow warnings (since I already have an ATO).
If I don't need to include anything, how can I reference the individual switches?
Posted: Mon Jan 09, 2012 8:59 am
Ah ok.
Sorry... I missed the beginning of the thread :(
The float switch ports can be checked with this function:
ReefAngel.LowATO.IsActive();
ReefAngel.HighATO.IsActive();
So, for example, you could use it like this:
  ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.Off(Port1);
Posted: Mon Jan 09, 2012 9:40 am
by Zechenia
Perfect! Thank you! Now I just gotta figure out how to mount them where I need em! lol
Ok, another (probably dumb) question. Which plugin is which? :)
Posted: Mon Jan 09, 2012 9:42 am
Posted: Mon Jan 09, 2012 9:50 am
by Zechenia
Thank you!
Posted: Tue Jul 03, 2012 12:24 pm
by Zechenia
Woo, finally purchased the Wi-fi. Can't wait til it shows up and I can play with it!
Things on the agenda, apart from adding wifi (including portal and android app, ect) is to add a softer start up. Whenever the power goes out, my GFI switch trips when it tries to start back up. I think it has to do with the amount of power suddenly starting again, so I'm going to see what I can do about turning stuff back on in stages.
