Wifi mystery
Posted: Wed Aug 26, 2015 4:21 am
by Marine007
The IP address that my wifi module was using is no longer in use (can't ping it even). But it is still transmitting data to the portal. How do I determine which IP address it is using?
Seems to start doing this after I connected the Bluetooth module.
Re: Wifi mystery
Posted: Wed Aug 26, 2015 5:02 am
best suggestion is to look at your routers configuration page and look at the wifi clients. then you can see the list of all the devices connected to your wifi.
Re: Wifi mystery
Posted: Wed Aug 26, 2015 12:24 pm
by Marine007
Thanks found it eventually - off course the last ip of 12 I checked.
Found that the wifi module is temperamental when connected through the Bluetooth adapter. Works no problem when connected directly, but have to be plugged in and out 3-4 times before the lights come on when connect through the Bluetooth.
