Manually set portal wifi address
Posted: Mon Aug 31, 2015 10:00 pm
by KRavEN
Is it possible to enter a url to manually set your portal wifi address without going through the wifi setup utility? I can reach my RA from the net with the RA app and via browser so port forwarding is all working properly.
Re: Manually set portal wifi address
Posted: Tue Sep 01, 2015 9:29 am
You can telnet it on port 2000, but the idle time is pretty short.
Posted: Wed Sep 09, 2015 2:55 am
by KRavEN
I meant is there a way to manually set the Wifi address on the
http://forum.reefangel.com/portal.php page. Mine has never been anything but blank.
Posted: Wed Sep 09, 2015 8:55 am
That would mean your RA is not sending data to the portal...and I think it is in the profile settings for the initial configuration.
Posted: Wed Sep 09, 2015 9:07 am
Yeah, if you go to the forum user profile, you can change, but if RA sends data to the portal, it will update that ip address to the most current one.
