Help with this PWM code
Posted: Thu Sep 03, 2015 10:24 am
by MDB1029
ReefAngel.PWM.SetChannelRaw(1,PWMSlopeHighRes(9,00,22,00,5,40,90,0));
So I am wanting these lights to go from 5% all the time, to ramp up to 40% starting at 9am through 10pm, basically using them as the moonlight until i can get dedicated moonlights so i can run them on the lunar cycle.
Is this possible or would i need another line of code that could control them from 10pm to 9am?
I am guessing i would need an entirely different string of lights on a different channel to use the actual lunar cycle code?
Re: Help with this PWM code
Posted: Thu Sep 03, 2015 10:48 am
by cosmith71
That line should do what you want. You may or may not be able to get them to go all the way down to 5. If they shut off, try a larger value for the bottom. I use my blues for moonlight and I only go down to 16.
You wouldn't necessarily need another string of lights, but the moonlight code runs best on a smaller string of lights. It's hard to get the variability you need with strong lights.
Posted: Thu Sep 03, 2015 2:39 pm
by MDB1029
Yeah the 5% is a bit high so I guess I will just go without until i can get dedicated lights. With the dimming expansion i wouldn't necessarily need the lunar module, just the lights right?
Posted: Thu Sep 03, 2015 6:18 pm
by cosmith71
I just realized that the 5 is a percent, not a raw value. You can definitely go lower than 5%
Your blues are on channel 0, right? Put these lines in after your regular lighting code in loop(). This will set a afterhours moonlight value of 16 raw. That's about as low as my LDD drivers would go. You may need to play with that value a little bit.
if ( ReefAngel.PWM.GetChannelValueRaw(0) < 16 || ReefAngel.PWM.GetChannelValue(0)>100)
    ReefAngel.PWM.SetChannelRaw(0,16);    // Set a default moonlight value for after hours
Posted: Thu Sep 03, 2015 7:58 pm
by MDB1029
Thank you I will try that when i get home
Posted: Thu Sep 03, 2015 10:32 pm
by MDB1029
cosmith71 wrote:I just realized that the 5 is a percent, not a raw value. You can definitely go lower than 5%
Sorry if i am showing my ignorance here, what is a raw value? I don't understand how that works.
Does this code mean i am not at 40% max?
Also do i need to change the starting % to something else here? 0?
Posted: Fri Sep 04, 2015 3:09 am
by cosmith71
Yes, change the 5 to a zero.
The values you're giving PWMSlopeHighRes are percents. So, 5 is the starting and ending percent, and 40 is the maxiumum percent.
It returns a raw value, which is from 0 to 4095 (which is why we're using SetChannelRaw). So when you ramp up to 40%, the corresponding raw value is about 1638. Using raw values is more complicated, but gives finer control as you have 4096 levels of dimming versus 100. In fact, there are a couple of functions smoother than PWMSlopeHighRes. I need to look into them, but I'm out of time this morning. :D
Posted: Sat Sep 05, 2015 6:51 am
by MDB1029
So i added the above code for the moonlight. It worked but the time is now 9:49am and the blue lights are still at the moonlight level.
Posted: Sat Sep 05, 2015 7:02 am
by cosmith71
Post your code again.
Posted: Sat Sep 05, 2015 7:13 am
by MDB1029
My blues are on channel 1 not 0 so I attempted to switch that, i probably didn't do it correctly. So I am going to switch which channel my whites and blues are on and use your code as it is. I will post the code when i am done and will keep you updated.
Posted: Sat Sep 05, 2015 7:16 am
by MDB1029
    int DaylightPWMValue=0;        // For cloud code
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port2 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
    ReefAngel.SingleATOLow( Port5 );
        DaylightPWMValue=PWMSlopeHighRes(10,00,20,0,0,45,60,0);
     CheckCloud();
     ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
    ReefAngel.PWM.SetChannelRaw(0,PWMSlopeHighRes(9,00,22,00,0,40,90,0));  // Blues from 0900 to 2200 on a slope
    ReefAngel.StandardLights(Port7,18,0,10,0);  // Fuge light from 1800 to 1000
    ReefAngel.Portal( "MDB1029" );
    ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 7
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 2
      // In this example, start cloud after noon
    #define Start_Cloud_After NumMins(12,00)
    #define End_Cloud_Before NumMins(21,00)
      // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
      // of effects or unforseen result could happen.
      // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
      // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
      // Add Random Lightning modes
    #define Calm 0    // No lightning
    #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
    #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
    #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
    #define Mega2 4   // Like Mega, but with more lightning
      // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
      // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
      byte LightningModes[] = {Mega2,Mega,Mega};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
      static time_t DelayCounter=millis();    // Variable for lightning timing.
      static int DelayTime=random(1000);      // Variable for lightning timimg.
    #ifdef forcecloudcalculation
      if (cloudchance==255)
    #else
    #endif
          randomSeed(millis());    // Seed the random number generator
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
          DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
          if (chooseLightning)
            chooseLightning=false;
          switch (lightningMode)
          case Calm:
            break;
          case Mega:
            // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              // Send the trigger
              Strike();
              DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
              DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
            break;
          case Mega2:
            // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
            // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
              else lightningstatus=0;
              if (lightningstatus)
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          if (cloudindex < numclouds)
        /*ReefAngel.LCD.Clear(255,0,120,132,132);
         ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
          int x=0;
          else x=17;
          //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
          ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
          else x=35;
          //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
          ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
        //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
        ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
        if (lightningchance)
          int x=0;
          if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
          else x=57;
          //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
          ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
          if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
          else x=75;
          //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
            ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
    void Strike()
      int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
      for (int i=0; i<a; i++)
        // Flash on
        int newdata=4095;
        Wire.beginTransmission(0x40);      // Address of the dimming expansion module
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
        Wire.write(newdata>>8);            // This sends the MSB
        Wire.endTransmission();
        int randy=random(20,80);    // Random number for a delay
        if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
        delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
        // Flash off.  Return to baseline.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
        Wire.beginTransmission(0x40);    // Same as above
        delay(random(30,50));                // Wait from 30 to 49 ms
        wdt_reset();    // Reset watchdog timer to avoid re-boots
      cstart*=60;
      cend*=60;
      if (n>cend) return (int) PWMStart;
Posted: Sun Sep 06, 2015 4:41 am
by cosmith71
I have no idea why that shouldn't work. I use it myself.
Try this. Remove these lines:
And replace them with this:
        if (hour()>=22 || hour()<9) ReefAngel.PWM.SetChannelRaw(0,16);
Posted: Mon Sep 07, 2015 8:28 am
by MDB1029
cosmith71 wrote:I have no idea why that shouldn't work. I use it myself.
I switched the channel 0 to blues and the channel 1 to whites, re-copied the lightning code and the moonlight code you gave me and everything works perfect now.
I really appreciate all the help that you provide me
Posted: Mon Sep 07, 2015 8:32 am
by cosmith71
Awesome! You're welcome!
