Custom Variable Questions
clw143
Post by clw143 »
1). How can I set the initial value of a custom variable so it is not changed to 0 during a reset?
2). Is there a way to get the Custom Variable location to hold/display on the app a value higher than a byte (255)?
Re: Custom Variable Questions
Do you want always the same value or a different value?
clw143
Post by clw143 »
At reset it would just default to a set value instead of 0. I then would be able to change it as needed.
Just set the value on the setup() section.
clw143
Post by clw143 »
Thanks.
How about the variable being able to hold more than 255?
Not at the moment :(
