help understanding a line of code in PWM cloud effect PDE
Posted: Fri Jan 06, 2012 3:49 pm
Hi All-
I have the PWM module and am going line by line through the code I post below and I am trying to figure out if I missed the decleration of the variable "day" or if somehow its implicitly implied in the statement I underlined. I am a bit confused what day is referencing in the logic statment on that line... a little help please
perhaps just explain what exactly that is doing. Kinda still getting a grasp on logic in c++ as it uses different text for some comparators than VBasic which I know a bit more about.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
#else
#endif
if (cloudchance)
