EMERGENCY! RA+ bricked 15 hours before my flight!
Posted: Wed Oct 07, 2015 6:06 pm
by gaberosenfield
I'm supposed to get on a plane to go to my girlfriend's brother's wedding tomorrow morning. So I go to upload some updated code on my RA+ and I get this message:
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 44,976 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_command(): failed miserably to execute command 0x1d
avrdude: stk500v2_cmd(): failed to send command
And then it just keeps repeating this loop. The RA screen goes black, the red light blinks, then stays on and the screen never comes back and nothing is working! No lights, no pumps, nothing. I try again. Same result. I try unplugging the RA+ and plugging it back in: same result. I try uploading my code and pressing the reset button in the head unit right when arduino says "Rebooting ReefAngel controller": same result. Now I'm desperate? What happened? What do I do? And before anyone asks, no none of the electronics have been exposed to water.
Please help!
Re: EMERGENCY! RA+ bricked 15 hours before my flight!
Posted: Wed Oct 07, 2015 7:57 pm
by Kungpaoshizi
Be sure to email Roberto!
Sorry I don't have better advice :(
Posted: Wed Oct 07, 2015 8:50 pm
Have you tried loading a different code?
Posted: Wed Oct 07, 2015 11:16 pm
by gaberosenfield
Yes. I tried reloading the standard code, as well as some example codes. It is not an issue with the code. It is an issue with the head unit. Currently I have my old RA standard running the bare essentials. Hopefully that will be enough for the next 5 days while I am out of town. Unless there is some other way to reset the RA+, I think I'll have to send it back to you and get a new one or something...
Posted: Wed Oct 14, 2015 7:59 am
by gaberosenfield
I'm back from Texas now, and my tank has survived so far. What should I do about my faulty RA+ roberto? Should I send it to you? Will you send me a replacement? How does this work? If necessary I could drive down to Fremont to speak with you in person.
Gabe
Sent from my SAMSUNG-SM-G870A using Tapatalk
Posted: Wed Oct 14, 2015 10:24 am
PM me for RMA number
Posted: Sat Oct 17, 2015 5:05 pm
by gaberosenfield
So I took my RA+ board to Roberto. He was able to upload multiple different .ino files to it with no problem. I picked up a USB power cable from him and tried again with my computer at home: same problem, no matter what code I used. I tried again from my girlfriend's computer: same problem. I cannot upload anything to the RA+, even though Roberto had no problem on his computer. Could this be a mac issue that has suddenly appeared? Roberto was using a PC and both my girlfriend and I have macbook pros. I'm just at a loss now...
Just for clarification, I know it is something with the RA+, because I can upload to my old RA standard just fine. But even when I try to upload the exact same code to the RA+, it just bricks on me. And yes I am selecting the correct board and port on my computer before uploading. Any ideas?
Gabe
Posted: Sat Oct 17, 2015 5:47 pm
Do you have a PC you can try?
Posted: Sat Oct 17, 2015 7:53 pm
Thats an odd one.
Posted: Sun Oct 18, 2015 9:41 am
by gaberosenfield
I don't have a PC... maybe I can borrow a friends... Has anyone else had problems with their Mac? It seems strange because it never had a problem before.
Posted: Thu Oct 22, 2015 10:46 pm
by gaberosenfield
Ok, I finally got it working. I booted into windows on my macbook pro and tried uploading to my RA+ from there. It worked when I tried uploading an example code, but then had the same error as before when I tried uploading my code. After that, when I tried uploading the example code again, it wouldn't work. But arduino in windows gave a different error. It said "COM3 is already in use". I googled "COM3 already in use arduino windows 8". The results I got suggested that this was a pretty common error and that you need to either restart your computer or try switching to a different USB port. I did the latter and was able to upload an example code again.
I decided there must be something about my code that was causing this COM3 in use error to occur and brick my RA+. I went through and deleted all the unused variables in my code (remnants of past incarnations of my code that I never completely deleted) and commented out functions that I'm not using at the moment. I tried uploading again and VOILA! It works!
I don't know exactly what in my code was causing this error, but the COM3 error only appeared on arduino in windows, not in OSX. I also don't know why whatever was in my code that caused this never caused it before. All I changed from the last time my code worked to when this error started was I changed a timeout for one of the pumps in my automatic water change system from 30 minutes to an hour. I have no idea how that resulted in the COM3 error appearing.
Anyway, everything is working again now and I can finally breath a huge sigh of releif :-) Thank you Roberto for your help!
Posted: Fri Oct 23, 2015 4:52 am
Very odd. The code should have NOTHING to do with your com port.
