custom main font help
Posted: Sun Jan 08, 2012 3:27 pm
by psyrob
Curt:
I am trying to use DrawLargeText for a custom main, and I have the fonts defined in the features file, but I keep getting the error "No member name DrawLargeText"
Can you spot what's wrong?
pde
#define DisplayImages
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte wmport=Port5;
boolean wmdelay=false;
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "ROB'S REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 17, 132, 17);
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 115, 132, 115);
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 90, 132, 90);
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 8, 21, "Main Tank:");
char text[7];
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
//ReefAngel.LCD.Clear(DefaultBGColor,43,20,73,20);
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 88, 20, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 50, 58, "pH:");
//ReefAngel.LCD.Clear(DefaultBGColor, 98, 33, 128, 33);
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 88, 58, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,33,"Frag Tank:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
88, 33, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,47,"Room Temp:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
88, 47, 10);
here's the features file
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8X8
#define FONT_8X16
#endif  // __REEFANGEL_FEATURES_H__
Re: custom main font help
Posted: Sun Jan 08, 2012 3:41 pm
by psyrob
Or anyone....
Posted: Sun Jan 08, 2012 4:11 pm
by binder
That is a puzzler. I tested it out on my computer and was having similar problems. Here's how I fixed it (don't ask why it works, it just did). This is what I did. I did the extra compiles to test that things were being included properly.
Comment out the FONT_8x8 and FONT_8x16 lines
Comment out the DrawLargeText line.
Compile your code.
Uncomment the FONT_8x8 line (you don't really need the 8x16 line according to your code usage)
Compile your code.
Uncomment the DrawLargeText line.
Compile your code again.
That should work.
Posted: Sun Jan 08, 2012 5:16 pm
by psyrob
Well, tried it, got to the last step (uncomment DrawLargeTest) and it is again giving the "No member " error...
Posted: Sun Jan 08, 2012 5:51 pm
by psyrob
You know, it was working to do large or huge numbers, I had those defined in the features file, but I removed them...don't know if that gives a hint...
Posted: Sun Jan 08, 2012 6:21 pm
You will not believe what the problem is... lol
#define FONT_8X8
#define FONT_8X16
You used capitalize "X" and it has to be lower case :ugeek:
Posted: Sun Jan 08, 2012 6:25 pm
by psyrob
:oops: ARRRRGGGG!!!!!!! :lol:
Posted: Sun Jan 08, 2012 8:25 pm
by binder
Haha. That thought crossed my mind too but I wasn't paying close attention when I was testing it. Guess that's what I get for not paying close attention. :)
Posted: Mon Jan 09, 2012 9:06 am
by rufessor
THANKS for the reminder guys!
hahahah... I think I was doing the SAME thing! I KNOW that C++ is case sensitive but old habits are hard to break!!
