Dimming bleed over
Posted: Tue Nov 24, 2015 5:02 pm
by Lionfan
Today I noticed that my lights are flickering on one channel.
And it's in sequence with my wavemaker.
And a few times when I manually adjust it to "0" it will do the complete opposite and go to 100.
My lights are CT lites, 0-5 V PWM.
Re: Dimming bleed over
Posted: Tue Nov 24, 2015 10:26 pm
Are you having issues with bus lock?
Posted: Wed Nov 25, 2015 12:07 pm
by Lionfan
rimai wrote:Are you having issues with bus lock?
I was at one point, but I removed my labels from the code and haven't had a bus lock since.
Posted: Wed Nov 25, 2015 2:19 pm
Is the wavemaker on the same dimming module?
Can you post the code?
Posted: Sun Nov 29, 2015 8:30 pm
by Lionfan
rimai wrote:Is the wavemaker on the same dimming module?
yes, its on the same expansion.
Here's the current code
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port5Bit;
    ReefAngel.LightsOnPorts = Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit;
    // Setup ATO Port for AI communication
    ReefAngel.AI.SetPort( lowATOPin );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardHeater( Port3,780,785 );
    ReefAngel.StandardFan( Port4,785,790 );
    ReefAngel.StandardLights( Port5,22,0,6,0 );
    ReefAngel.Relay.DelayedOn( Port6,1 );
    ReefAngel.WaterLevelATO( Port7,60,90,100 );
    ReefAngel.StandardLights( Box1_Port1,8,0,20,0 );
    ReefAngel.StandardLights( Box1_Port2,12,0,18,0 );
    ReefAngel.DosingPumpRepeat( Box1_Port3,0,30,240 );
    ReefAngel.DosingPumpRepeat( Box1_Port4,30,30,240 );
    ReefAngel.StandardLights( Box1_Port8,9,0,19,0 );
    ReefAngel.PWM.SetDaylight( PWMParabola(6,0,22,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(7,0,22,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(7,0,22,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(10,0,18,0,0,65,120,0) );
    ReefAngel.AI.SetChannel( White, PWMParabola(11,0,18,0,0,75,0) );
    ReefAngel.AI.SetChannel( Blue, PWMParabola(8,0,21,0,1,100,1) );
    ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(8,0,22,0,1,100,1) );
    ReefAngel.DCPump.SetMode( Else,50,10 );
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DCPump.ExpansionChannel[3] = Sync;
    ReefAngel.DCPump.ExpansionChannel[4] = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
            if(ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Override(Port6,0);
    ReefAngel.Portal( "lionfan" );
Posted: Sun Nov 29, 2015 8:40 pm
by Lionfan
Today I noticed alot of blinking, and the strangest thing ;
When I put the app on 0, the dimming expansion would spit out 10 volts.
When it was on 100, it spit out 0 volts. It did this until I unplugged it for a few minutes, and reset everything.
Posted: Mon Nov 30, 2015 12:08 pm
Could it be something with the DCPump and the PWM classes somehow messing with each other.
I'm confident that is not the case, but would you mind testing it be sure?
Remove the DCPump class and set the channel 3, 4 and 5 using the PWM class instead.
If you need help with the code, let me know what mode you would like to set for those channels.
You won't be able to change modes for this test though.
Posted: Mon Nov 30, 2015 9:13 pm
by Lionfan
rimai wrote:Could it be something with the DCPump and the PWM classes somehow messing with each other.
Tried it. No real luck.
Still getting random blinking
Posted: Wed Dec 02, 2015 1:51 pm
by Lionfan
I've changed all of the classes to PWM, and even changed the dimming expansion out (a friend of mine let me borrow his)
Still getting blinking, and lights cutting off.
Posted: Wed Dec 02, 2015 2:26 pm
Weird.
Is it connected directly to the relay box or through a hub?
Can you try directly to the relay?
If you still get the same problem, does it happen the same if you remove the code for the pumps?
Posted: Thu Dec 03, 2015 6:39 am
by Lionfan
rimai wrote:Weird.
I'll try both tonight.
Im thinking it might be a hub issue.
Im getting some random power clicks on the Reef Angel .
I actually replaced this hub about 3 months ago, so its a stretch that its messed up.
Posted: Thu Dec 03, 2015 9:17 pm
by Lionfan
Lionfan wrote:
rimai wrote:Weird.
The problem seems to go away when I plug up the dimming expansion directly to the relay.
This is really troubling because I just replaced the expansion hub a few months ago.
Posted: Fri Dec 04, 2015 8:48 pm
Do you have anything else connected to the hub?
Are you using the original USB cables?
Check for bad connection and try a different port in the hub.
Posted: Fri Dec 04, 2015 9:48 pm
by Lionfan
rimai wrote:Do you have anything else connected to the hub?
They are the original, although I wouldn't be surprised if they were the problem.
I have a relay expansion, a lunar hub, the dimming expansion, water level expansion, and the WiFi attachment hooked up.
I do get random power flicks time and time again, and even when my lunar hub is on 0, I still get a very dim light.
Random ATO timeouts happen, for no reason, but the controller continues to keep the tank topped off.
I think that's pretty much all my problems. Even with different codes, all this happens.
Posted: Fri Dec 04, 2015 9:51 pm
I think there is one module that is misbehaving and causing a bus lock. That's what would cause the dimming flickers and the relay clicks.
I would start with only one module connected and watching. Then add one at a time to find out which one it is.
Posted: Sat Dec 05, 2015 8:11 pm
by Lionfan
rimai wrote:I think there is one module that is misbehaving and causing a bus lock. That's what would cause the dimming flickers and the relay clicks.
I left my relay expansion unplugged for a few hours today, and that seems to have fixed it. I plugged it back in and still no problems.
I think it's the culprit.
