Expansion hub
Posted: Sat Nov 28, 2015 10:00 am
by Ismaclst
I bought a used expansion hub and I'm having an issue with it. I think it's the connection where the USB plugs in from the relay box. When I plug it in I get no power on the hub. If I wiggle the USB cable where it plugs into the expansion hub, the led power light will flicker. I tried two different USB cable's with the same results.
Re: Expansion hub
Posted: Mon Nov 30, 2015 11:08 am
by Ismaclst
Bump
Re: Expansion hub
Posted: Mon Nov 30, 2015 11:56 am
Looks like it is bad.
Re: Expansion hub
Posted: Tue Aug 16, 2016 8:09 pm
by bmhair03
Buy some good automotive dielectric grease. Silly to think these connection wouldn't corrode. Intended use and a Salt water aquarium are far apart. Protect your investment.
Re: Expansion hub
Posted: Tue Aug 16, 2016 8:17 pm
by bmhair03
If pin tension get loose.And it will weather you move connector or not. Micro fretting will result in bad connection i.e.:bus lock.
