Internal webserver UI
Hi Guys,
I changed the internal webserver to the Uapp UI.
To test it, use the latest dev branch.
Let me know how it works for you.
Re: Internal webserver UI
Cool. I need to start testing the dev code. I have some updates I want to do anyway
Roberto are we close to another release? Maybe we get a thread together with features to test etc? I feel like it may have been a while since the last one
Yeah, I think this is the last piece I wanted to add to this release.
Sweet! I have to go to Hong Kong next week. I should really wait till I'm back to update...
definitely wait until you are back. wouldn't want you to have an issue when you are halfway around the world.lnevo wrote:Sweet! I have to go to Hong Kong next week. I should really wait till I'm back to update...
All I get is a white screen with "Reef Angel Controller Web Server" in big black letters at the top. Tried Chrome, Edge, Firefox, and IE.
how do I update the controller to add the new UAPP Webserver?
You must go to page /wificosmith71 wrote:All I get is a white screen with "Reef Angel Controller Web Server" in big black letters at the top. Tried Chrome, Edge, Firefox, and IE.
That works much better.
How do I get it to pull up my values? It's all zeroes now.
Tried that. Do I need to enter in my forum username somewhere?
OK, not sure what was going on, but it's working with all four browsers now.
It always comes up with 0's until I refresh. First refresh almost always returns an "Unable to process controller data" message.
Controller labels have to be downloaded every session?
Custom variables without a label justify to the left instead of the center after downloading labels.
Changing DC pump modes shows the icon for the previous mode until refreshed.
Edit: Just tried it on a different computer and it works as expected?
Edit part 2: Speed and duration don't automatically refresh. If I go from a specified mode with default speeds to custom mode with hard-coded speeds, the new speed/duration doesn't change until I refresh.
I hope this kind of stuff is what you were looking for, otherwise I'm just being a jerk.
I get unable to retrieve data every time.
You must use the dev branch of our libraries.fishflipper wrote:I get unable to retrieve data every time.
Did you update it?
The problem is when you issue a wifi command to change something you get back OK and you don't get the same results like when setting a relay which returns the entire XML. Then you'd have to do a second query.cosmith71 wrote:Changing DC pump modes shows the icon for the previous mode until refreshed.
We could do 2 things to streamline that. Instead of sending just OK or ERR. We could put a status flag in the /sa /r99 output. It might break some of the current apps, but we'd just be adding the same tag it's looking for inside the rest of the output.
The other would be making the second call to the web ui to refresh. But I have issues sometimes if I query to quickly so a slight delay wouldn't be horrible. This btw, is all the same behavior of the current UApp also.
I thought I changed that. When the controller responds with OK, I update the UI.
I'll double check.
I may have only done that for the cloud server connection, now that you mentioned.
I'll double check.
Ok, so I just tested and it updates fine on my side.
I had DCPump in Constant mode.
Click the image, selected a new mode, the browser showed the spinning wheel for a brief second and it updated the UI with the mode I had selected.
I also did the same thing for the speed and duration, which updated the UI after the spinning wheel.
I did see the labels not being kept though.
I'll work on this shortly.
It happens to me when going from custom, with it's own hard-coded speed and duration, to any other mode. It shows the custom speed and duration until a refresh.
Also, there seems to not be an icon for gyre?
I implemented a delay when refreshing from that command in my app for the same reason. too fast of request will error out.lnevo wrote:The problem is when you issue a wifi command to change something you get back OK and you don't get the same results like when setting a relay which returns the entire XML. Then you'd have to do a second query.cosmith71 wrote:Changing DC pump modes shows the icon for the previous mode until refreshed.
Can you post the relevant code for me to replicate the problem?cosmith71 wrote:It happens to me when going from custom, with it's own hard-coded speed and duration, to any other mode. It shows the custom speed and duration until a refresh.
Here you go.
void PumpControl()
// ******************* Pump Control *******************
if (InternalMemory.DCPumpMode_read()==11) // If custom mode on Portal
ReefAngel.DCPump.UseMemory = false; // Turn off memory control
ReefAngel.DCPump.SetMode(Else,60,30); // If nothing changes it in the next few lines, this is what runs.
ReefAngel.DCPump.Threshold=20;
if (hour()>=22 || hour()<9) ReefAngel.DCPump.SetMode(Gyre,80,30,50); // Gyre max, duration, minimum
if (hour()>=9 && hour()<10) ReefAngel.DCPump.SetMode(Gyre,90,30,60); // Gyre max, duration, minimum
if (hour()>=10 && hour()<11)
ReefAngel.DCPump.SetMode(Else,40,20); // Else mode from 1000 to 1100. Wake up!
else ReefAngel.DCPump.UseMemory = true; // If it's not custom mode on the portal, then do what mode the portal says.
But if you are using usememory=false, you shouldn't be able to change speed and duration, right?
Yeah you're logic is a bit off..once in custom how do you get out?
Correct. Custom uses the hard coded values. Right now, they are gyre 80/30. The memory values for a non-custom mode are, say, 60/20. If I switch from custom with coded values of 80/30 to, say short pulse, the speed and duration still show the coded values of 80/30 instead of the memory values of 60/20 until I do a refresh. Same if I go back to custom from a memory mode. The mode display updates immediately, but the speed and duration values don't update on the screen until a refresh.
Lee, you can choose any mode you like from the DC Pump page. The code can tell when custom is selected.
Right nevermind. I misread the if statement. If memory is set to non custom the RF.UseMemory is true.
how do I update to the newest libraries?
