constant sketch too big
Posted: Mon Dec 07, 2015 5:37 pm
Hi,
I have had my code the same for over a year now. I used the wizard to try and tweak my heater timer settings. No matter what I do every sketch is saying it's too large. This is with both using in internal memory or in the code setting with the wizard.
The only thing that has changed is my pc is now on windows 10 - which somehow caused me to lose my old sketch settings. Mybe the ttl cable is not connecting? I hear my pc recognize it though.
here is an example:
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.StandardFan( Port2,780,790 );
ReefAngel.StandardLights( Port3,12,0,20,0 );
ReefAngel.StandardLights( Port4,10,30,20,30 );
ReefAngel.StandardFan( Port5,785,795 );
ReefAngel.StandardLights( Port6,6,0,1,0 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.StandardHeater( Port8,780,790 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,20,0,15,70,30,15) );
ReefAngel.PWM.SetActinic( PWMSlope(10,30,20,30,15,100,30,15) );
ReefAngel.Portal( "marvollo" );
here is an example:
