Feed and water change not working
Posted: Tue Dec 08, 2015 7:59 am
Good morning all,
I added a custom wave function I found on the site, its working great but since I changed it my water change/feed mode is not turning off the jebao wavemakers. Could someone please let me know where I went wrong?
ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
// Define labels for 2014 LCD screen
//box0
ReefAngel.CustomLabels[0]="T5HO";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="FugeLight";
ReefAngel.CustomLabels[3]="Heater";
ReefAngel.CustomLabels[4]="ScrubLight";
ReefAngel.CustomLabels[5]="Unused";
ReefAngel.CustomLabels[6]="Return";
ReefAngel.CustomLabels[7]="ATO_Pump";
ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
ReefAngel.MHLights( Port2,5,0,22,0,5 ); //skimmer
ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
ReefAngel.StandardHeater( Port4,780,788 ); //heater
ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
ReefAngel.SingleATO( true,Port8,300,0 ); // ato
// Wave Makers
if (hour()>=7 && hour()<10)
{ ReefAngel.PWM.SetDaylight( SineMode(0,100,300,true) ); // Long pulse at 100% with 300s pulse on sync mode
ReefAngel.PWM.SetActinic( SineMode(0,100,300,false) ); // Long pulse at 100% with 300s pulse on anti-sync mode }
else if (hour()>=10 && hour()<12)
{ ReefAngel.PWM.SetDaylight( SineMode(0,100,180,true) ); // Sine Wave at 100% with 180s pulse on sync mode
ReefAngel.PWM.SetActinic( SineMode(0,100,180,false) ); // Sine Wave at 100% with 180s pulse on anti-sync mode }
else if (hour()>=12 && hour()<15)
{ ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% +/- 20% on anti-sync mode }
else if (hour()>=15 && hour()<17)
else if (hour()>=17 && hour()<20)
{ ReefAngel.PWM.SetDaylight( SineMode(0,35,400,true) ); // Sine Wave at 35% with 300s pulse on sync mode
ReefAngel.PWM.SetActinic( SineMode(0,35,400,false) ); // Sine Wave at 35% with 300s pulse on anti-sync mode }
