Port toggle for driver reset
Posted: Sat Jan 23, 2016 2:27 am
by tyson_mitchell_88
Hi,
I need to flick a port off and on again. Thought something like this but I'm not sure if I'm remotely right.
//White off
if (hour()==18 && minute()==30 && second()>=0 && hour()==18 && minute()==30 && second()<2)
ReefAngel.Relay.Off(Port8);
} else {
ReefAngel.Relay.On(Port8);
Or is it just
//White off
if (hour()==18 && minute()==30 && second()==0)
} else {
Re: Port toggle for driver reset
Posted: Sat Jan 23, 2016 4:53 am
by cosmith71
Either of those should work. I'd go with the first one just because it has a little more delay.
Be aware that except for those two seconds, that port will ALWAYS be on with that code. You would also need to place it after any other code that controls that port.
Posted: Sat Jan 23, 2016 5:32 am
So if I go with this it should just turn off for those 2 sec. Otherwise will be on 500 > 2100.
Thanks Colin
//White off
} else {
ReefAngel.StandardLights( Port8,5,00,21,00 );
Posted: Sat Jan 23, 2016 5:41 am
by cosmith71
There are a couple of ways.
You can do it the way you have posted.
You can do this, too.
//White off
if (hour()==18 && minute()==30 && second()<2)
} else {
You could also have the StandardLights up higher in your loop() and leave out the else completely.
loop()
ReefAngel.Standardlights( Port8,5,0,21,0);
Posted: Sat Jan 23, 2016 5:52 am
Yep changing it to the second way. Should of thought of it from the start lol. Thanks mate
