Custom menu question
Posted: Thu Jan 12, 2012 5:47 pm
by maxxdog21
I am going to try my hand at building a custom menu. One of the entries that I would like to have is the ability to manually turn on one set of lights. Could you advise me on how to do this?
Re: Custom menu question
Posted: Thu Jan 12, 2012 7:41 pm
I use this:
void MenuEntry4()
  ReefAngel.Relay.RelayMaskOn|=B00001100;  //Override Lights On;
  ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
My lights are on Port 3 and 4.
You can move the 1s to whatever port you have your lights.
Posted: Fri Jan 13, 2012 7:34 pm
by maxxdog21
Thanks Roberto. I put in the code and when I tried to compile it, it gave me an error message that the sketch was too big. I can make it work if I take out the 4th menu entry - set time and date. I don't really don't need it but what if I want to add another menu entry? Like a nother wavmaker mode? Will it be too big again? Why is my code so big?
Posted: Fri Jan 13, 2012 7:37 pm
by maxxdog21
This was my running pde file - all I added were the custom menu lines. Here is the code:
#define DateTimeSetup
#define DisplayLEDPWM
#define RelayExp
#define wifi
#define VersionMenu
#define PWMEXPANSION
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES  4
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Salinity.h>
#include <ReefAngel_Colors.h>
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Time";
prog_char menu2_label[] PROGMEM = "Lights On";
prog_char menu3_label[] PROGMEM = "Set time and date";
menu0_label, menu1_label, menu2_label, menu3_label};
void MenuEntry1()
      ReefAngel.DisplayMenuEntry("Feeding Time");
      ReefAngel.FeedingModeStart();
void MenuEntry2()
      ReefAngel.DisplayMenuEntry("Water Change");
void MenuEntry3()
     ReefAngel.DisplayMenuEntry("Lights On");
     ReefAngel.Relay.RelayMaskOn|=B00000001; //Override Lights On;
void MenuEntry4()
     ReefAngel.DisplayMenuEntry("Set time and date");
     ReefAngel.SetupDateTime();
byte PWMChannel[]={
  0,0,0,0,0,0};
  //Top Banner
  ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Harry's 120H Reef ");
  // Display Temp Text
  ReefAngel.LCD.DrawText(0,255,8,12,"Temp");
  // Display the T1 temp value
  char text[7];
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  ReefAngel.LCD.Clear(255, 4, 22, 37, 38);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 22, text, Num8x16);
// Display Salt Text
  ReefAngel.LCD.DrawText(0,255,54,12,"Salt");
  // Display Salt Value
  ReefAngel.LCD.Clear(255, 52, 22, 75, 38);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 52, 22, text, Num8x16);
  // Display pH Text
  ReefAngel.LCD.DrawText(0,255,112,12,"pH");
  // Display pH Value
  ReefAngel.LCD.Clear(255, 94, 22, 106, 38);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 94, 22, text, Num8x16);
// Display Actinic Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,40,"Blue LED %");
// Display Actinic Percentage Value
   ConvertNumToString(text, PWMChannel[1], 1);
   strcat(text,"  ");
   ReefAngel.LCD.DrawText(0, 255, 80, 40, text);
 // Display Daylight Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,50,"White LED %");
 // Display Daylight Percentage Value
   ConvertNumToString(text, PWMChannel[0], 1);
   strcat(text,"  ");
   ReefAngel.LCD.DrawText(0, 255, 80, 50, text);
 // Display Moonlight Phase Text
  ReefAngel.LCD.DrawText(0,255,8,60,"Moonlight ");
 // Display Moonlight Phase Value
  ConvertNumToString(text, PWMChannel[2], 1);
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(0, 255, 80, 60, text);
  ReefAngel.LCD.DrawOutletBox(13, 109, TempRelay);
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.FeedingModePortsE[0] = B00110000;
  ReefAngel.WaterChangePorts = B00111100;
  ReefAngel.WaterChangePortsE[0] = B00110011;
  ReefAngel.OverheatShutoffPorts = B00000011;
  ReefAngel.LightsOnPorts = B00011110;
  ReefAngel.Relay.On(Port3);
  ReefAngel.Relay.On(Port4);
  ReefAngel.Relay.On(Box1_Port2);
  // Wavemaker timer
  ReefAngel.Timer[1].SetInterval(random(15,90));
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port6);
  ReefAngel.Relay.On(Box1_Port6);
  // Specific functions
  // T5 White
  ReefAngel.StandardLights(Port1,10,30,20,0);
  //T5 Blue
  ReefAngel.StandardLights(Port2,9,30,20,45);
  //LED Blue
  ReefAngel.StandardLights(Port7,9,0,21,15);
  //LED White
  ReefAngel.StandardLights(Port8,10,0,20,30);
  //Heater
  ReefAngel.StandardHeater(Box1_Port3,773,783);
  //Refugium
  ReefAngel.StandardLights(Box1_Port4,21,0,7,0);
  //Fan
  ReefAngel.StandardLights(Box1_Port7,8,30,21,0);
  //LED Moonlight
  ReefAngel.StandardLights(Box1_Port8,20,45,7,30);
  // Channel 0 = White
  PWMChannel[0]=PWMSlope(10,0,20,30,0,100,30,PWMChannel[0]); // calculate slope %
  // Channel 1 = Blue
  PWMChannel[1]=PWMSlope(9,0,21,15,0,100,30,PWMChannel[1]); // calculate slope %
  // Channel 2= Moonlights
  PWMChannel[2]=MoonPhase(); // calculate moon phase %
  // this section sends the data to the PWM expansion module
  for (int a=0;a<4;a++)
    ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
  // Wavemaker
    ReefAngel.Relay.Toggle(Box1_Port5);
    ReefAngel.Relay.Toggle(Box1_Port6);
Posted: Fri Jan 13, 2012 7:39 pm
by maxxdog21
And my features file as well:
// AutoGenerated file by RAGen (v1.1.0.124), (10/22/2011 19:43)
 * Copyright 2010-11 Curt Binder
 * Licensed under the Apache License, Version 2.0 (the "License")
// #define SIMPLE_MENU
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules  1
#define WDT
#define SALINITYEXPANSION
#define CUSTOM_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#endif  // __REEFANGEL_FEATURES_H__
Do you have a wifi attachment?
Posted: Fri Jan 13, 2012 7:48 pm
by maxxdog21
Yes, I do. I do not have it running yet but it's next on the to do list... :D
Posted: Fri Jan 13, 2012 7:54 pm
Ok, so you can remove the date/time setup. It takes quite a bit of memory.
You can use the wifi very easily to update the time.
Make sure to also remove this line in the features file:
Posted: Fri Jan 13, 2012 7:58 pm
by maxxdog21
I did try that and the pde will compile. The time/date is big - That's what I thought. But, if I want to add another menu entry of any kind, will the code be too big again or will it be okay(being that the t/d function is huge)?
Posted: Fri Jan 13, 2012 8:00 pm
You should be good.
Posted: Sat Jan 14, 2012 2:49 pm
Adding menu entries does not increase code size by a whole lot. The more complex the function is, the larger the code size increase will be. I cannot give you an example, just a general guideline.
Posted: Sat Jan 14, 2012 9:59 pm
by maxxdog21
I figured as much. The time/date code segment must be big, even if it seems to be a simple function.
Posted: Sun Jan 15, 2012 6:56 am
yes it is big. there is a lot that has to be done with updating the screen on the changes. so it does require some space.
