Coding Jebao RW series pumps
Posted: Tue Feb 16, 2016 9:44 am
by Civics14
So, for the RW pumps since it can run at a lower speed than the WP series and it seems like the ReefAngel DC pump settings are default to a min. 30% since I never see it go below that.
So, how do I program for... let's say else mode for 30% is the median and 15% up/down from there? Because ReefAngel.DCPump.SetMode (Else, 30, 15); is going min. 30 and max 45, when I want min. 15 and max 45.
Also, why can't we get a sticky that explains these pump settings and what they do? The DC Pump thread is if you understand programming, why not have anything in laymen's terms?
Re: Coding Jebao RW series pumps
Posted: Tue Feb 16, 2016 12:53 pm
I think you need to change the threshold.
Add this to your setup()
InternalMemory.DCPumpThreshold_write(15);
Posted: Tue Feb 16, 2016 4:00 pm
You should be able to also add a hardcode
ReefAngel.DCPump.Threshold=15;
Posted: Fri Feb 19, 2016 11:30 am
by Civics14
Awesome. Thanks everyone.
